1 - 2 of 2 Posts
I had my belts changed on my '98 Jetta GT 2.0. I also had my Cam and Crank seals changed at the same time. For some reason the crankseal is continuing to leak every time they install it (they have done it 4 or 5 times now)
. does anyone know why this is.
Could this be because of positive crank case pressure? I have Swiss Cheesed air box w/K&N panel, APR chip and exhaust.
I blew in and sucked out of both openings of the PCV valve and air flowed freely.
Please help or direct me to the correct place.
Discussion Starter · #2 ·
Re: Crank seal keeps leaking oil. Why? (GTspeed)
If it is because of extra crank case pressure can I put a crank case ventelator on? Those little fliter things I've seen on the honda's around town.
1 - 2 of 2 Posts
