Re: Crap....brakes died. I need quick answers on a few 11"/rear disc swap questions (duff_man2000)
Good....I thought MK3 knucles would fit. If you have them on your ride with 10.1s, I can stick them on my ride with 11s....I just needed to know the knuckles would fit with the arms, struts, and the diveshafts. Good deal.
I found those locally for $75 a side, used, from a 98 Jetta.
I found the rear beam, complete, with brakes (dunno if they are any good though), for $250, from an 87 GLI.
I wanted the entire rear beam for the swap because my GL has no prop valve on the rear beam....and I need one of those. My current prop valve is on the MC, which I will be replacing with a MC which had no prop valve on it...so I need a prop valve. Rear disc cars have a prop valve on the rear beam, so I decided to grab the whole beam, prop valve and all, and bolt it up, taking the chance to insert poly inserts into the rear beam bushings.
Thanks for the reply!
Broke
Broke
