1 - 20 of 32 Posts
Re: (RandomDubber)
yeah but when you think about it, if you were to have all that work done you'd only be saving a couple hundred dollars and taking 3x as long. Guess if you've got the cash and are wanting a fast car fast, it could be justifiable
Re: (beardhare)
Quote, originally posted by beardhare »
Eurospec has motors too.
Quote, originally posted by Eurospec »
Eurospec 2.2 Liter 4-Cylinder 16V Engines
Eurospec's 2.2 liter 16V powerplant greatly improves on the reliable but otherwise unexciting 2.0 liter ABA engine by not only increasing displacement, but also converting the cylinder head from a single cam to a more efficient double cam setup with 4 valves per cylinder. The increased flow and individual intake and exhaust cams provide a substantial power increase, especially at the upper RPM limit where airflow is critical. Combined with the larger displacement, the Eurospec 2.2 liter 16V engine is an incredible performer with an abundance of horsepower and torque throughout the powerband.
Our engine blocks use special proprietary designed JE forged pistons available in a wide range of compression ratios for either turbo or naturally aspirated appliations, 4340 forged 100mm stroke crankshaft, 159mm forged connecting rods, ARP hardware, and German high performance bearings. Long blocks add a new complete cylinder head. Sport cams and larger valves are additional.
Short Blocks include:
# Forged 4340 100mm stroke crankshaft
# Eurospec H-Beam 159mm connecting rods w/ARP 3/8" bolts
# Forged JE pistons in your choice of compression
# New oil pump
# Main bearings, German high performance
# Rod bearings, German high performance
# Steel head gasket
# Main bearing girdle with ARP hardware
# Oil pan
Long Blocks include:
Includes everything above, plus:
# New 4-Valve cylinder head
# Timing belt pulleys and Eurospec tensioner
# ARP head studs
Part Number
ESB 100 2200 4V
Description
2.2 Liter Short Block - Forged crank, forged pistons, Eurospec rods, Eurospec main bearing girdle
Starting Price
$4,700
Part Number
ELB 100 2200 4V
Description
2.2 Liter Long Block - Forged crank, forged pistons, Eurospec rods, Eurospec main bearing girdle, cylinder head, timing accessories
Starting Price
$6,650
little bit better priced from eurospec
Re: crate engines? (ejand22)
eurospec http://****************.com/smile/emthup.gif
eip http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif
Re: (Road Boss)
Quote, originally posted by Road Boss »
I see they don't have any love for the 8v?
Your joking right?
Eurospec has dozens of 8v options, from 1.6 complete motors to their own big port heads for cis and digi cars
1 - 20 of 32 Posts
