Re: Cross Drilled Brakes vs. Slotted Brakes (winkosmosis)
Quote, originally posted by winkosmosis » |
I don't understand the vented rotors that aren't drilled. Where does the air come from that should be pulled through by the fins? |
Well, from my past experiance with heatsinks, the great the surface area the more chance there is for air to move over the surface to remove that heat build up. Though, there is certain limitations to which must be met. The distance between filns generally can be no greater than the surface of the fin. Well, that applied when I was making a few prototype heatsinks for Tektronix that is.
With cross drilled rotors I can see the benefit with the air going through the holes to be sucked or blown out the center section. With slotted, the air is sucked intot he slot as the rotor is going under the pad and the only escape being the end of the slot.
I have been told by some peopel that cross drilled is meant for racing purposes as with the venting and such. I currently have Zimmerman cross driled rotor and axis carbon kevlar pads on my car and I can't believe the stopping power I have.
As a note about the MB with the flat faced rotors, we can't assume that they are using the same composition of rotor that we use on our car. Another thing to think about with a flat faced rotor, there is more surface area of contact to use when at the higher speeds, possibly a reason why they did that.
Just my $.02 on that one.
