Re: Cruise control out? (MP3DUB)
I can share my experience with cruise control on my '92 B3... BTW it's a 16V with auto trannie....
The nice old lady who owned the car previously told me that CC was working sometime, and sometime not. So i tried it, it was not working, and sometime it works... But Here's what I found after my little and personal study of the system...
When it works, it works great, gas pedal goes straight down and hold the speed perfectly. Since my car is an automatic, i only have a pedal switch on the brake pedal. When the cruise was not working, i tried to pull the pedal gently with my foot... ET VOILÀ, the cruise was working again. So my pedal switch was not working accuratly. Now I know that, so everytime i try to use the Cruise and it'S not working, I only pull the pedal for about 5 milimeters, and it works. But I found that the desactivation of the Cruise with brake pedal is VERY sensitive. If I even only touch the pedal, the Cruise desactivate. As per my Bentley, it seems that the Cruise control pedal switch is not the same than the Brake light switch. Cruise switch is supposed to br Vacuum switch. When weather will become warmer (still under zero in Quebec...), I'll checl if there is an adjustment on that switch... So maybe you can try this !! I'll keep you posted with the results of my further investigation...
Anyone has the same problem????
