1 - 9 of 9 Posts
CTS Turbo Product Listing - Check out the amazing MK4 products we manufacture and products from other great companies!
CTS Turbo VW MK4 R32 3" Cat-back Exhaust
The CTS Turbo MK4 R32 cat-back exhaust system is hand tig welded using the finest T304 stainless steel. The other MK4 R32 exhausts that are currently available choke peak power and limit the R32s breathing due to their 2.5" construction. The 3" design is ideal R32's equipped with turbochargers or superchargers, and those of us chasing serious horsepower.
Product Details:
- True 3" Stainless steel cat-back exhaust
- Increased power gains especially with forced induction
- Aggressive sound under hard driving, but subtle when cruising
- Water jet cut flanges
- CNC mandrel bent stainless steel piping
- Polished stainless steel exhaust tubing
Price: $899.99 - CLICK HERE to place an order & for more product information.
CTS Turbo R32 T4 V-band Downpipe
Building a custom R32 turbo setup? Looking for a downpipe to support 600+HP and install with ease?
We've got what you need! The CTS R32 Turbo Downpipe is hand crafted with premium stainless steel and CNC machined V-band flanges.
This downpipe is designed to fit Precision T4 flanged turbos and TiAL 44/MVR or Precision 46mm V-band wastegates, MUST be used with CTS Turbo exhaust manifold. Clamp is not included, please select from drop-down menu. *NOTE: made to order part, lead time 5-10 business days.
Price: $699.99 - CLICK HERE to place an order & for more product information.
Fuel Rail, CTS Turbo MK4/MK5 Volkswagen R32 & 8P Audi A3 3.2L 24V VR6 Fuel Rail
High flow fuel rail
Price: $149.99 - CLICK HERE to place an order & for more product information.
CTS MK4 R32 Turbo Kits - Stage 2, Stage 3, Stage 4
Stage 2 MKIV R32 Turbo Hardware Kit: This Kit is a hardware only kit, and includes a host of parts to make your dub into a street sleeper. The kit is centered around a Precision HP6266 (600HP capable) turbocharger. The kit also includes a 3" vband high flow Stainless Steel Downpipe, T4 flanged cast exhaust manifold, Precision 46mm wastegate, FMIC Kit with High Density Intercooler (24"x12x3.5", 4 Ply Silicon Couplers, Stainless Steel T bolt clamps, and all the necessary hardware you need to. With a 3" cat-back exhaust, 94 octane fuel and 7-8 lbs of boost you should see approximately 375hp.
Stage 3 MKIV R32 Turbo Hardware Kit: This kit is also a hardware only kit, and includes all of the components from the stage 2 kit, along with a Stainless Steel Head Spacer kit which reduces the compression ration from 11.3:1 down to 8.5:1 to allow for higher boost levels and cylinder pressures. With a 3" cat-back exhaust, 94 octane fuel and 15-16psi of boost you should see approximately 450hp.
Stage 4 MKIV R32 Turbo Hardware Kit: This kit is also a hardware only kit, and includes a Stainless Steel Head Spacer kit which reduces the compression ration from 11.3:1 down to 8.5:1 to allow for higher boost levels and cylinder pressures. With a 3" cat-back exhaust, 94 octane fuel and 18-20psi of boost you should see approximately 500+hp and 600+HP with the motor build option.
Starting at: $4999.99 - CLICK HERE to place an order & for more product information.
CTS Turbo R32 Short Runner Intake Manifold
This high flow short runner intake manifold should be on the shopping list for any high power R32 turbo project car. Aluminum construction allows extreme boost pressures, which the stock intake manifold cannot hold due to its plastic construction. This is the same short runner intake manifold used in our CTS stage 4 R32 turbo kit, rest assured this is a quality piece that has been tested in excess of 700HP.
Starting Price: $699.99 - CLICK HERE to place an order & for more product information.
CTS R32 / 24V Turbo Manifold (T4 flanged)
This is the same exhaust manifold featured in our MK5 R32 turbo kit. Casted from inconel-type steel, this manifold is extremely strong and will last for many years. Using this manifold, your car is bound to produce the horsepower figures you are looking for.
This is the perfect manifold for the DIY turbo kits.
Applications: Volkswagen/Audi 3.2L engines and 2.8L 24V VR6
Material: Inconel Alloy
Outlet Flange: T4
Wastegate Flange: 44mm TiAL/46mm Precision (Vband)
Shown with optional thermal coating.[/B]
[B]Price: $549.99 - [URL="http://www.ctsturbo.com/cart/products/CTS_R32_24V_Turbo_Manifold_T4_flanged-465-2.html"]CLICK HERE to place an order & for more product information[/URL]. [/B]
[B][U]CTS MK4 HEAD SPACER KIT - 12v & 24v VR6[/U][/B]
[IMG]http://www.ctsturbo.com/cart/images/products/thumbs/r32headspkit.jpg
The CTS Turbo head spacer gasket for the MK4 12v & 24v VR6 motor. Lowers the compression to 9:1. Comes with gaskets included.
Price: $299.99 - CLICK HERE to place an order & for more product information.
CTS MK4 R32 Crank & Power Steering Pulley Kit
Light weight aluminum power pulleys - Crank & Power steering pulley included with kit
Price: $199.99 - CLICK HERE to place an order & for more product information.
CTS 24v/r32 SAI blockoff plate
This plate allows the removal of the secondary air injection/combi valve system on MK4 24V VR6 or MK4 R32/Audi TT 3.2L.
Will not fit MK5 R32/Audi A3 3.2L. Proper software must be used to remove the check engine light and ensure correct engine operation.
Kit includes block-off plate with hose barb, OEM gasket and screws.
Price: $39.99 - CLICK HERE to place an order & for more product information.
ARP Head Bolt Kits, Head stud kits & More
These are high quality, American made main stud kit for VW engines, brought to you by ARP out of California. This is absolutely the highest quality main stud kit you can find. We are genuine ARP distributors so buying from us guarantees you a valid warranty. Completely reusable, great for race engines.
Price: Visit website for pricing and options - CLICK HERE to place an order & for more product information.
JE Pistons - VW Mk4 1.8T, 2.0L, VR6
-Dome/Dish requires no deburring or preparation
-2618 T6 high tensile forged aluminum
-JE designs are specifically engineered for extreme applications up to, and including, professional competition. In this environment, the higher compression ratios, highest boost or heavy nitrous usage necessitate the higher tensile strength 2618 aluminum alloy.
-Wrist pins included
-Pin fitting and wire locks included
-Rings Now Included
Price: Contact us or visit our website - CLICK HERE to place an order & for more product information.
Mahle PowerPack 84.5MM Bore 9:1 CR R32 VR6 Piston Set
This is a set of extremely high quality Mahle PowerPack pistons for 4 & 6 cyl. VW. Mahle Powerpack pistons are extremely high quality pieces which provide improvements in strength over OEM pistons without some of the sacrifices sometimes found in other forged pistons. Mahle Powerpack pistons are precision forged from 2618 alloy, a low expansion rate aluminum. They all feature forged side reliefs, reducing the weight of the overall package. They also use slipper skirt designs, reducing friction and further reducing weight. Mahle PowerPack pistons feature ultra flat ring grooves, which promote excellent ring seal and most importantly reduce the chances of micro-welding during break in. Every set of Mahle PowerPack pistons comes with their exclusive Grafal skirt coating, which is not only anti-friction but also offers impact absorbing qualities, reducing piston noise and decreasing stresses in the piston skirt.
Price: Contact us - CLICK HERE to place an order & for more product information.
Integrated Engineering 4 & 6 cyl. connecting rods
High quality rods, a must for your engine build!
Price: Contact Us - CLICK HERE to place an order & for more product information.
Ferrea, Supertech & Integrated Engineering Valve Spring Kits
A must for high revving engines!
Ferrea MK4 4 & 6 cyl Valves
Ferrea is one of the most known names when it comes to valvetrain. That is because they make the finest quality valvetrain available! Ferrea valvetrain is trusted by the top racing teams around the world. Formula 1, Nascar, indy, drag racing, and road racing teams all utilize Ferrea valvetrain in the world's highest performing engines. It is definitely a notch above the rest.
Wavetrac Differentials MK4 - 4 & 6 cyl appliactions
Each Wavetrac Differential is crafted from the highest quality materials available. The internal gears are made from high strength 9310 alloy steel. The diff bodies are machined from case hardened steel billet. To complete the package, every Wavetrac differential is built exclusively using high quality, high strength fasteners from ARP, the world leader in fastener technology. For more information please visit the link below
Starting at: $995.00 - CLICK HERE to check out the options we have available or place an order.
BFI Engine Mounts - MK4 - 4 & 6 cyl.
Maximizing bushing area to minimize vibration where possible gives our mount the advantage of having the best ride characteristics possible from a urethane bushing mount.
Stage 1 with its 65a durometer bushings are geared towards the spirited enthusiast who wants better control over motor movement without the sacrifice of excessive vibrations. *We only recommend Stage 1 mounts for stock and lightly modified Mk4 2.8l 12v VR6 vehicles.
Stage 2 with its 85a durometer bushings are for the enthusiast who is looking for maximum performance from his motor mounts - great for modified street cars and track cars. *We recommend Stage 2 mounts for highly modified 2.8l 12v and ALL 2.8l & 3.2l 24v VR6 vehicles.
Each complete replacement mount comes with two bushings, one 304 stainless base plate, one 6061 aluminum center bracket, and all washers and hardware necessary to mount to your vehicle.
Solo-Werks S1 Coilovers - MK4 R32 AWD
Premium entry level height adjustable coilovers
Price: $499.00 - CLICK HERE to place an order & for more product information.
If there are any questions, comments or to place an order you can PM or email me at [email protected] or call us at 604-530-3092[/B]
Discussion Starter · #2 · (Edited)
Outlet Flange: T4
If you have any additional questions please feel free to contact us.
CLICK HERE TO ORDER
1 - 9 of 9 Posts
