CTS Turbo is proud to offer a variety of turbo kits that can easily turn your MK4 .:R32 into a world class supercar killer. The power potential starts with a state of the art Precision 6262S turbocharger which is equipped with the latest in aerodynamic compressor wheel design, CEA Billet Compressor wheel (Competition Engineered Aerodynamics).
You want big power out of your R32 right? Well you'll need to efficiently control the boost and the immense amount of exhaust gases exiting the boosted 3.2L. Yeah, we've got you covered with the Precision V-band 46mm external wastegate, T4 flanged exhaust manifold with V-band wastegate provision, and a 3" V-band downpipe.
Topping this kit off is the CTS 750HP FMIC, don't you hate it when you buy parts and you need to change them to meet your power goals 6 months later? Well we've got you covered, each kit includes a CTS 750HP FMIC, 2.5" stainless steel piping hot and cold side, stainless steel T-bolt clamps, and 4 ply silicon connectors.
In short, if you're looking for big power out of your R32 and a hardware setup that can support between 350HP and 750HP then you're looking in the right spot. Please take some time to check out our products below, we have a variety of turbocharger offerings for every power goal.
Stage 2: MK4 R32 Stage 2 kits starting @ $4,799.99
Stage 2 MKIV R32 Turbo Hardware Kit Features:
- Precision HP6262S (670HP capable) T4 Flanged
- Stainless steel turbo heat shield
- Thermal coated turbine housing & exhaust manifold
- CTS R32 Turbo Manifold
- Precision 46mm Vband Wastegate
- 3" Stainless Steel Downpipe
- Oil Feed/Drain Kits with all required fittings
- 3" Turbo Intake Pipe
- Re-useable Air Filter
- 4ply Silicone Hoses and Stainless Steel T bolt Clamps
- High Density Intercooler Core
- Black Sandtex Powder Coated Intercooler Tubing
- Gaskets, Studs, Nuts, Clamps
- Bosch Diverter Valve
Stage 3: MK4 R32 Stage 3 kits starting @ $5,199.99
Stage 3 MKIV R32 Turbo Hardware Kit Features:
- 8.5:1 Stainless Steel Head Spacer Kit (with gaskets)
- Inline Fuel Pump Kit & Fuel Filter
- High Density Intercooler Core 750HP core
Stage 4: MK4 R32 Stage 4 kits starting @ $5,799.99
Stage 4 MKIV R32 Turbo Hardware Kit Features:
- Short runner intake manifold
