1 - 17 of 17 Posts
CTS Turbo Product Listing - Check out the amazing MK5 products we manufacture and products from other great companies!
CTS Turbo Oil Catch Can System 2.0TFSI
MK5 2.0T FSI - 2006 to 2008
Price: $349.99 - Click here to place an order & for more information and a video of one of our cans being drained.
CTS Turbo Oil Catch Can System 2.0TSI
MK5 2.0TSI - 2008 to 2010
Price: $449.99 - Click here to place an order & for more information and a video of one of our cans being drained.
CTS TURBO - TSI BREATHER ADAPTER
Direct fit for Gen1 and Gen2 2.0T TSI engines (included in our TSI catch can system)
Price: $199.99 - CLICK HERE to place an order & for more product information.
CTS Turbo PCV Revamp Kit FSI/Golf R
The CTS PCV revamp was designed primarily as a fix to the PCV problems that commonly occur on FSI motors including the Golf R, which include poor idle, poor gas mileage, oil seepage through oil cap, irregular boost pressure.
Price: $89.99 - CLICK HERE to place an order & for more product information.
CTS Turbo Valve Cover Breather Adapter 2.0T FSI
This is the CTS Turbo Valve Cover Breather adapter for 2.0T FSI engines including Golf R
Price: $99.99 - CLICK HERE to place an order & for more product information.
CTS noise pipe delete kit for FSI/TSI motors
This kit will allow you to remove the factory "noise pipe"
Price: $24.99 - CLICK HERE to place an order & for more product information.
CTS CEL Eliminator / O2 Sensor spacer
OFF ROAD USE ONLY
Price: $39.99 - CLICK HERE to place an order & for more product information.
CTS Turbo FSI/Golf R Intake Manifold Flap Delete
The CTS Runner Flap Delete allows for the removal of the restrictive intake flappers from the factory intake manifold.
Price: $149.99 - CLICK HERE to place an order & for more product information.
CTS Turbo O2M/O2Q Short Shift Kit
Fits MK5 with 6 speed manual transmission - works on other vehicles also, see application list on our site
CTS Turbo Billet Subframe Bushing Insert Kit: MK5/MK6/MK7/8P/8V/MK2 Audi TT
This kit is designed to eliminate the clunk that is commonly found on MK5's and MK6's due to the stretching of OEM bolts stretching and failing
Price: $139.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK5 Torque Arm Insert 05.5-08
CTS Turbo MK5 FSI (2005.5-2008.5) torque arm insert is designed to eliminate excessive movement in the factory mounting
Shifter Bracket Bushing - O2Q
Eliminate free-play and slop in your factory shifter bracket by replacing soft factory rubber bushings
Price: $69.99 - CLICK HERE to place an order & for more product information.
CTS Turbo FSI/TSI Throttle Body Spacer
These spacers offer a injection point for water/meth systems as well as increase in plenum volume.
CTS Diverter Valve Relocation Adapter FSI / TSI
CTS Diverter Valve Relocation Adapter for stock diverter Valve 2.0T FSI & TSI
Price: $59.99 - CLICK HERE to place an order & for more product information.
CTS Turbo TSI/FSI DV blockoff Flange
This part allows you to remove the factory Diverter Valve from turbos on 2.0T FSI/TSI engines
Price: $29.99 - CLICK HERE to place an order & for more product information.
CTS MK5/MK6 TSI Crank Pulley Kit
The CTS Turbo crank pulley is lightened to reduce parasitic drag on the engine.
CTS MK5 FSI Crank Pulley Kit
Price: $179.99 - CLICK HERE to place an order & for more product information.
FSI RS4 Injector Set of 4 (079 906 036D)
B7 RS4 fuel injectors which are primarily used when upgrading fuel systems for VW and Audi FSI motors
Price: $349.99 - CLICK HERE to place an order & for more product information.
S3 Fuel Injector Set of 4
These injectors flow 13% more the factory A3/MKV 2.0T FSI injectors. They bolt on with no modding and are the perfect upgrade to anyone going to a bigger turbo.
Price: $499.99 - CLICK HERE to place an order & for more product information.
CTS Turbo FSI Auxiliary Low Pressure Fuel System
CTS has developed a fully integrated fueling system, which utilizes a secondary in-tank fuel pump that is capable of supporting in excess of 600HP
CTS Drop In High Flow Fuel Pump Kit For FSI/TSI
The CTS Drop In High Flow Fuel Pump Kit For FSI/TSI is the simplest and most effective way of increasing your low pressure to attain maximum performance. Simply remove your original in-tank fuel pump, install our new High Flow Fuel Pump Kit and you're done, this unit drops right in and supports in excess of 500HP.
Autotech FSI High Pressure Fuel Pump Upgrade Kit
Our HPFP Kit can achieve flow rates 50% higher than the original pump, essentially removing pump limitations from the equation, even on high-end turbo upgrades.
Price: $359.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK5 FSI Air Intake System
The OEM air scoop works in conjunction with our sealed airbox to seamlessly force cold air into our air intake system.
Price: $299.99 (optional heat shield add $19.99) - CLICK HERE to place an order & for more product information.
CTS Turbo MK5 TSI Air Intake System - EA888.1
Price: $329.99 (add breather filter for SAI $9.99) - CLICK HERE to place an order & for more product information.
CTS Turbo Golf R/FSI 3" Intake System
After many requests to build a true 3" intake we at CTS Turbo we are proud to announce our new 3in air intake system for the Golf R and MK5 FSI. Please note this kit is most commonly used with the GIAC "Extreme File" for K04 tuning, and will not work with most standardized software.
CTS Turbo FSI/Golf R Throttle Pipe
The OEM charge piping leaves something to be desired with inefficient bends, blockages not optimized for performance. The CTS Turbo throttle pipe increases the entire inside diameter to 2.5" allowing for increased flow and greater performance.
Price: $169.99 - CLICK HERE to place an order & for more product information.
CTS Turbo TSI Throttle Pipe
CTS Turbo FSI (K03) Turbo Outlet Pipe (TOP)
The CTS Turbo FSI (K03) Turbo Outlet Pipe (TOP) is designed to replace the narrow 'pancake' pipe that comes as factory equipment on your K03 turbo equipped FSI. Our Turbo Outlet Pipe features 2.25" diameter aluminium tube for optimized flow.
Price: $229.99 - CLICK HERE to place an order & for more product information.
CTS Turbo TSI Turbo Outlet Pipe (TOP)
The CTS Turbo TSI Turbo Outlet Pipe (TOP) is designed to replace the narrow 'pancake' pipe that comes as factory equipment on your vehicle.
Our Turbo Outlet Pipe features 2.25" diameter aluminum tube for optimized flow.
CTS Turbo TSI K04 Turbo Outlet Pipe (TOP)
This Turbo Outlet Pipe is designed to fit our CTS TSI K04 kit and replaces the narrow 'pancake' pipe that comes as factory equipment on your vehicle.
CTS MK5 2.0T Direct Fit FMIC Kit
CTS Direct fit intercooler, direct replacement for the stock unit, much larger then stock, lowers operating temps
Price: $799.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK5 2.0 TFSI BorgWarner K04 Turbo Upgrade Kit
The heart of the CTS Turbo MK5 2.0TFSI turbo upgrade kit is the Borg Warner K04-0064 turbocharger. This turbocharger is commonly used in OEM applications such as the Audi S3 available in Europe. Power with Unitronic Stage 2+ tune: 335hp/335lb-ft tq
Price: $1949.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK5 2.0 TSI BorgWarner K04 Turbo Upgrade Kit
The heart of the CTS Turbo MK5 2.0TSI turbo upgrade kit is the Borg Warner K04-0064 turbocharger. This turbocharger is commonly used in OEM applications such as the Audi S3 available in Europe.
CTS TURBO MK5 2.0 FSI BIG TURBO KIT
CTS Big Turbo Kits - Please click the link for more information and to view options
Price: starting at $3699.99 - CLICK HERE to place an order & for more product information.
CTS TURBO MK5 2.0 TSI BIG TURBO KIT
Price: starting at $3999.99 - CLICK HERE to place an order & for more product information.
Borg Warner Replacement Turbos - from stock to K04, we have something for you!
CTS Turbo VW MK5 GLI 3" Cat-back Exhaust
True 3" Stainless steel cat-back exhaust
Aggressive sound under hard driving, but subtle when cruising
CNC mandrel bent stainless steel piping
Polished stainless steel exhaust tubing
Price: $749.99 - CLICK HERE to place an order & for more product information. Sound clips can also be found on our site!.
CTS Turbo VW MK5 GTI 3" Cat-back Exhaust
Water jet cut flanges
Price: $699.99 - CLICK HERE to place an order & for more product information. Sound clips can also be found on our site!.
CTS Turbo VW MK5 GTI 3" Turbo-back Exhaust
True 3" Stainless steel turbo-back exhaust
Adjustable 3" exhaust tips
To remove the CEL that will occur, proper tuning software must be used. CTS Turbo recommends choosing a High Flow Cat for the sake of our environment!
Price: $1099.99 - CLICK HERE to place an order & for more product information. Sound clips can also be found on our site!.
CTS Turbo MK5/A3 FSI 2.0T FWD Downpipe
T304 Seamless Stainless Steel tubing
T304 Stainless Steel flanges
100% TIG Welded
T304 Stainless Steel 02 bungs
Stainless Steel Clamps
Great Sound
Price: $399.99 for catless, add $100 for highflow cat - CLICK HERE to place an order & for more product information..
100% TIG Welded
Great Sound
CTS Turbo Blow Off Adaptor for VAG FSI, TFSI, TSI Turbo Engines
The CTS spacer is a great solution for open air venting, without converting over to a full blow-off valve. Run it with or without software, not worrying about a check engine light. Works best with Revision D factory diverter valve.
CTS TURBO 2.0T DIVERTER VALVE KIT (EA113, EA888.1)
CTS Turbo is proud to release our 2.0T Atmospheric BOV KIT for EA888.1 equipped vehicles. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) is made of billet construction and completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars. Be sure to check out our video at the link below.
Price: $249.99 - CLICK HERE to place an order & for more product information.
CTS TURBO 2.0T BOV (BLOW OFF VALVE) KIT (EA113, EA888.1)
CTS Turbo is proud to release our 2.0T DV (DIVERTER VALVE) KIT for EA113 and EA888.1 equipped vehicles. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT is made of T6061 billet construction and is completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
In addition to our own products above, we are also distributors for a bunch of great other manufactures. If you do not see what your looking for just ask and I will be glad to help.
Just a few of the other great companies we deal with.
Solo-Werks Coilovers
ST Coilovers
SouthBend/DXD Clutches
Black Forest Industries (BFI)
Wavetrac Differentials
Borg Warner Turbos
If there are any questions, comments or to place an order you can PM or email me at [email protected] or call us at 604-530-3092
Discussion Starter · #2 ·
CTS VW MK5 2.0T Direct Fit FMIC Kit
The CTS MK6 2.0T Direct Fit FMIC Kit is designed as a drop in replacement for the OEM front mounted intercooler (FMIC). That means you can install this kit without any trimming or modification of the bumper. The OEM FMIC is adequate for stock boost levels, however once boost levels are increased by way of ECU upgrades/chipping the OEM FMIC struggles to keep the charged air temperatures in check. Higher charged air temperatures can result in boost cut and timing pull, both reducing the amount of power your vehicle produces.
The CTS direct fit FMIC uses a high efficiency bar and plate intercooler core, which aids in reducing pressure drop. Reducing pressure drop means that your turbo will not have to work as hard to make a given level of boost. If your turbo makes 30psi of boost pressure in the turbocharger, and your intercooler has a 10psi pressure drop then the boost measured by your ECU would be (30psi - 10psi) = 20psi. With an efficient FMIC like the CTS direct fit FMIC your turbo does not have to work as hard to reach desired boost levels. This is beneficial in two ways, the turbo life expectancy is increased due to more efficient operation, and boost leaving the turbocharger is cooler and more dense resulting in more power to the ground.
Product Details:
- Efficient bar and plate construction
- Direct bolt-in installation
- 4-ply silicon hoses and billet adapter to turbo outlet pipe
- High quality stainless steel clamps
- Low pressure drop
- Maintains factory mounting points
- No trimming of bumper or crash supports
- Rated for power levels in excess of 600HP
- Core dimensions: 23.00 Length x 2.00" Tall x 16.5" Height
- Cast aluminum end tanks with mounting points that are CAST into the end tank, NOT welded like inferior intercoolers
Price: $799.99 USD shipped in the USA & Canada - CLICK HERE TO ORDER
Discussion Starter · #3 · (Edited)
CTS Turbo MK5 FSI CATCH CAN KIT - $349.99 Shipped
CLICK HERE TO ORDER FSI CATCH CAN KIT
CTS Turbo is proud to offer the premier catch can solution for the MK5 GTI and MK5 Jetta GLI with 2.0 TFSI motors.
The oil catch can is used prevent oil vapors entering the intake manifold and clogging up the intake valves on direct-injection motors. Oil deposits on intake manifold and valves cause reduced performance, bad fuel mileage and could damage the fragile intake “flaps” and motor.
Kit Includes:
CTS Turbo billet aluminum valve cover breather – CNC machined for beautiful finish
CTS Turbo Billet aluminum catch can with billet oil-level dipstick
-10 AN Black-Series braided hoses
Oil catch can mounting bracket
Modular intake manifold plug
Hose-Wrangler clamp
Kit Fits:
· 2006 - 2008 MK5 Volkswagen GTI 2.0 TFSI
· 2006 - 2008 MK5 Volkswagen Jetta GLI 2.0 TFSI
All installation hardware is included. No drilling or hacking away at your car required. Not compatible with noise pipe, please select the noise pipe delete kit from drop-down menu. Complete bolt-on installation.
Keep your GTI/Jetta running smooth, clean and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
CTS Turbo MK5 TSI CATCH CAN KIT - $449.99 Shipped
CLICK HERE TO ORDER TSI CATCH CAN
CTS Turbo is proud to offer the premier catch can solution for the MK5 GTI 2.0 TSI motors. This catch can kit is for the late MK5 vehicles that have the new TSI motors in MK5 chassis.
Kit Includes:
Hose-Wrangler clamp
Kit Fits:
· 2008 - 2009 MK5 Volkswagen GTI 2.0 TSI
· 2009 - 2010 MK5 Volkswagen Jetta 2.0 TSI
All installation hardware is included as well as new o-ring for rear PCV. No drilling or hacking away at your car required. Not compatible with noise pipe, please select the noise pipe delete kit from drop-down menu. Complete bolt-on installation.
Keep your MK5 GTI TSI running smooth, clean and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
New lower pricing on our Blow Off Valve Kits!
New Price: $249.99 USD Shipped in the USA & Canada. CLICK HERE TO ORDER
Fitment:
Audi A3 8P (EA113 & EA888.1)
MKII Audi TT (EA113 & EA888.1)
MK5 GTI (EA113 & EA888.1)
MK5 Jetta (EA113 & EA888.1)
MK6 GTI (EA888.1)
MK6 Jetta (EA888.1)
EOS (EA113 & EA888.1)
Tiguan (EA888.1)
B6 Passat (EA113 & EA888.1)
Passat CC (EA888.1)
Beetle (EA888.1)
Audi S3 8P (EA888.1)
Golf R (EA888.1)
Product Features:
T6061 billet aluminum construction
Black anodized stealth finish
Fully compatible with OE electronics
Fully serviceable piston design
No additional wiring required
Substantial reliability improvement over OE
Compact design fits into tight spots easily
Discussion Starter · #7 ·
CTS BOSS Turbo Kit for mk5 mk6 b7 b8 side by side with our 3D printed prototype. Many hours of R&D, 3D scanning and 3D printing ensure a perfect bolt on OEM fit for our kits feat. Honeywell Garrett gtx2867r and gtx3071r
We are in the final stages of testing. Stay posted for an announcement of when they will be available
Boss MK5 by CTS Turbo, on Flickr
Discussion Starter · #10 ·
Oktoberfest Fun Fact: Paris Hilton was permanently banned from Oktoberfest for dressing too skimpy and hawking canned wine back in 2006.
Fun Fact No. 2: Our CTS Oktoberfest sale is on. You can save up to 25% on our best selling performance parts for your auto. SALE on till October 3rd. Available for online orders only. store.
Discussion Starter · #15 ·
🏁🏁🏁Our annual Black Friday Sale goes live this Friday November 24th! Save up to 25% on our best selling performance parts for your VW Audi or BMW 🏁🏁🏁
Anyone who orders over $250 during the sale period will be entered into a draw for a Swag pack and a $500 gift card!
Discussion Starter · #16 ·
Discussion Starter · #17 ·
🏁🏁🏁Due to customer feedback we've extended our sale to January 2nd! Save up to 25% on our best selling performance parts for your VW Audi or BMW 🏁🏁🏁
>>>SHOP HERE <<<
1 - 17 of 17 Posts
