1 - 6 of 6 Posts
CTS Turbo Product Listing - Check out the amazing MK6 products we manufacture and products from other great companies!
CTS Turbo Oil Catch Can System MK6 TSI
2010+ MK6 Volkswagen GTI/Jetta GLI – North America
2010+ MK6 Volkswagen GTI/Jetta GLI – R.O.W.
2009+ MK2 Audi TT 2.0 TSI
2009+ MK2 Audi A3 2.0 TSI
2009+ MK6 Volkswagen Tiguan – North America
2009+ MK6 Volkswagen Tiguan – R.O.W.
Price: $449.99 - Click here to place an order & for more information and a video of one of our cans being drained.
CTS TURBO - TSI BREATHER ADAPTER
Direct fit for Gen1 and Gen2 2.0T TSI engines (included in out TSI catch can system
Price: $199.99 - CLICK HERE to place an order & for more product information.
CTS noise pipe delete kit for FSI/TSI motors
This kit will allow you to remove the factory "noise pipe"
Price: $24.99 - CLICK HERE to place an order & for more product information.
CTS CEL Eliminator / O2 Sensor spacer
OFF ROAD USE ONLY
Price: $39.99 - CLICK HERE to place an order & for more product information.
CTS Turbo O2M/O2Q Short Shift Kit
Fits MK5 with 6 speed manual transmission - works on other vehicles also, see application list on our site
Price: $149.99 - CLICK HERE to place an order & for more product information.
CTS Turbo Billet Subframe Bushing Insert Kit: MK5/MK6/MK7/8P/8V/MK2 Audi TT
This kit is designed to eliminate the clunk that is commonly found on MK5's and MK6's due to the stretching of OEM bolts stretching and failing
Price: $139.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK6 Torque Arm Insert 2009-2014
CTS Turbo MK6 (2009-2014) torque arm insert is designed to eliminate excessive movement in the factory mounting. These are 65A on the durametric scale which is the best hardness to minimize vibrations and drastically increase your vehicle's performance.
Features:
- Designed with CAD software for precision fit
- Virtually eliminates wheel hop
- More consistent shifting for manual and DSG transmissions
- Minimum increase in NVH
- Includes grade 10.9 hardware for install
Our inserts are Made in USA using DuPont Adeprene urethane designed specifically for this application
Shifter Bracket Bushing - O2Q
Eliminate free-play and slop in your factory shifter bracket by replacing soft factory rubber bushings
Price: $29.99 - CLICK HERE to place an order & for more product information.
CTS Turbo FSI/TSI Throttle Body Spacer
These spacers offer a injection point for water/meth systems as well as increase in plenum volume.
Price: $69.99 - CLICK HERE to place an order & for more product information.
CTS Diverter Valve Relocation Adapter FSI / TSI
CTS Diverter Valve Relocation Adapter for stock diverter Valve 2.0T FSI & TSI
Price: $59.99 - CLICK HERE to place an order & for more product information.
CTS Turbo TSI/FSI DV blockoff Flange
This part allows you to remove the factory Diverter Valve from turbos on 2.0T FSI/TSI engines
CTS MK5/MK6 TSI Crank Pulley Kit
The CTS Turbo crank pulley is lightened to reduce parasitic drag on the engine.
CTS Drop In High Flow Fuel Pump Kit For FSI/TSI
The CTS Drop In High Flow Fuel Pump Kit For FSI/TSI is the simplest and most effective way of increasing your low pressure to attain maximum performance. Simply remove your original in-tank fuel pump, install our new High Flow Fuel Pump Kit and you're done, this unit drops right in and supports in excess of 500HP.
Price: $499.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK5 TSI Air Intake System - EA888.1
The OEM air scoop works in conjunction with our sealed airbox to seamlessly force cold air into our air intake system.
Price: $329.99 (add breather filter for SAI $9.99) - CLICK HERE to place an order & for more product information.
CTS Turbo TSI Throttle Pipe
The OEM charge piping leaves something to be desired with inefficient bends, blockages not optimized for performance. The CTS Turbo throttle pipe increases the entire inside diameter to 2.5" allowing for increased flow and greater performance.
Price: $169.99 - CLICK HERE to place an order & for more product information.
CTS Turbo TSI Turbo Outlet Pipe (TOP)
The CTS Turbo TSI Turbo Outlet Pipe (TOP) is designed to replace the narrow 'pancake' pipe that comes as factory equipment on your vehicle.
Our Turbo Outlet Pipe features 2.25" diameter aluminum tube for optimized flow.
CTS Turbo TSI K04 Turbo Outlet Pipe (TOP)
This Turbo Outlet Pipe is designed to fit our CTS TSI K04 kit and replaces the narrow 'pancake' pipe that comes as factory equipment on your vehicle.
Price: $229.99 - CLICK HERE to place an order & for more product information.
CTS MK6 2.0T Direct Fit FMIC Kit
CTS Direct fit intercooler, direct replacement for the stock unit, much larger then stock, lowers operating temps
Price: $799.99 - CLICK HERE to place an order & for more product information.
CTS Turbo MK6 2.0TSI BorgWarner K04 Turbo Upgrade Kit
The heart of the CTS Turbo MK6 2.0TSI turbo upgrade kit is the Borg Warner K04-0064 turbocharger. This turbocharger is commonly used in OEM applications such as the Audi S3 available in Europe. Power with Unitronic Stage 2+ tune: 335hp/335lb-ft tq
Price: $1949.99 - CLICK HERE to place an order & for more product information.
CTS TURBO MK5 2.0 TSI BIG TURBO KIT
CTS Big Turbo Kits - Please click the link for more information and to view options
Starting at $3999.99 - CLICK HERE to place an order & for more product information.
Borg Warner Replacement Turbos - from stock to K04, we have something for you!
CTS Turbo VW MK6 Jetta Gen 1 3" Turbo-back Exhaust
Each CTS downpipe is 100% tig welded, constructed using 3" T304 Seamless Stainless Steel, and includes stainless steel clamps. Lesser products can be had without stainless steel construction, or with seamed stainless steel, which can crack and decay over time. The CTS Turbo downpipe eliminates the factory downpipe, increases turbo spool up, and peak power. The increased piping diameter of 3" allows for exhaust gases to exit the turbo and wastegate with less turbulence which all result in more power and torque throughout the entire powerband.
Price: $1149.99 - CLICK HERE to place an order & for more product information. Sound clips can also be found on our site!.
CTS Turbo VW MK6 Jetta Gen 3 3" Turbo-back Exhaust
CTS Turbo MK6 GTI 3" Turbo Back Exhaust
CTS Turbo MK6 GTI 3" Cat Back Exhaust
T304 Seamless Stainless Steel tubing
T304 Stainless Steel flanges
100% TIG Welded
T304 Stainless Steel 02 bungs
Stainless Steel Clamps
Great Sound
Price: $749.99 for catless - CLICK HERE to place an order & for more product information..
CTS Turbo VW MK6 Jetta 3" Cat-back Exhaust
100% TIG Welded
Great Sound
Price: $749.99 CLICK HERE to place an order & for more product information..
CTS Turbo MK6 TSI 2.0T FWD Downpipe
100% TIG Welded
Great Sound
Price: $399.99 for catless, add $100 for highflow cat - CLICK HERE to place an order & for more product information.. [/B
CTS Turbo Blow Off Adaptor for VAG FSI, TFSI, TSI Turbo Engines
The CTS spacer is a great solution for open air venting, without converting over to a full blow-off valve. Run it with or without software, not worrying about a check engine light. Works best with Revision D factory diverter valve.
Price: $89.99 - CLICK HERE to place an order & for more product information.
CTS TURBO 2.0T DIVERTER VALVE KIT (EA113, EA888.1)
CTS Turbo is proud to release our 2.0T Atmospheric BOV KIT for EA888.1 equipped vehicles. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) is made of billet construction and completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars. Be sure to check out our video at the link below.
Price: $249.99 - CLICK HERE to place an order & for more product information.
CTS TURBO 2.0T BOV (BLOW OFF VALVE) KIT (EA113, EA888.1)
CTS Turbo is proud to release our 2.0T DV (DIVERTER VALVE) KIT for EA113 and EA888.1 equipped vehicles. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT is made of T6061 billet construction and is completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
In addition to our own products above, we are also distributors for a bunch of great other manufactures. If you do not see what your looking for just ask and I will be glad to help.
Just a few of the other great companies we deal with.
Solo-Werks Coilovers
ST Coilovers
SouthBend/DXD Clutches
Black Forest Industries (BFI)
Wavetrac Differentials
If there are any questions, comments or to place an order you can PM or email me at [email protected] or call us at 604-530-3092
Discussion Starter · #2 ·
Our MK6 Catch Cans are Back In-stock & Ready to ship!
Click here to order
CTS Turbo is proud to offer the premier catch can solution for the MK6 GTI, MK6 Jetta, Audi A3, Audi TT with 2.0 TSI engines.
The oil catch can is used prevent oil vapors entering the intake manifold and clogging up the intake valves on direct-injection motors. Oil deposits on intake manifold and valves cause reduced performance, bad fuel mileage, and could damage the fragile intake “flaps” and motor.
Kit Includes:
CTS Turbo billet aluminum valve cover breather – CNC machined for beautiful finish
CTS Turbo Billet aluminum catch can with billet oil-level dipstick
-10 AN Black-Series braided hoses
Oil catch can mounting bracket
Modular intake manifold plug
Hose-Wrangler clamp
Kit Fits:
· 2010+ MK6 Volkswagen GTI/Jetta GLI – North America
· 2010+ MK6 Volkswagen GTI/Jetta GLI – R.O.W.
· 2009+ MK2 Audi TT 2.0 TSI
· 2009+ MK2 Audi A3 2.0 TSI
· 2009+ MK6 Volkswagen Tiguan – North America
· 2009+ MK6 Volkswagen Tiguan – R.O.W.
The mounting solution is available for left-hand side of engine bay for North American cars or right-hand side of engine bay for vehicles with charcoal canister.
NOTE: if you have aftermarket engine mounts, please choose driver's side (left side) mount.
Driver's (left) side mounting is only compatible with CTS Turbo or Carbonio intake systems.
Not compatible with Noise Pipe - please select the noise pipe delete kit from drop-down menu if your car comes with noise pipe.
All installation hardware is included, as well as o-ring for rear PCV. Complete bolt-on installation.
Keep your MK6 TSI running smooth, clean and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
CTS Turbo MK6 Torque Arm Insert 2009-2014 - In-stock & Ready to Ship!
Features:
Our inserts are Made in USA using DuPont Adeprene urethane designed specifically for this application.
CLICK HERE TO ORDER - $39.99 SHIPPED
Discussion Starter · #4 ·
New lower pricing on our Blow Off Valve Kits!
New Price: $249.99 USD Shipped in the USA & Canada. CLICK HERE TO ORDER
Fitment:
Audi A3 8P (EA113 & EA888.1)
MKII Audi TT (EA113 & EA888.1)
MK5 GTI (EA113 & EA888.1)
MK5 Jetta (EA113 & EA888.1)
MK6 GTI (EA888.1)
MK6 Jetta (EA888.1)
EOS (EA113 & EA888.1)
Tiguan (EA888.1)
B6 Passat (EA113 & EA888.1)
Passat CC (EA888.1)
Beetle (EA888.1)
Audi S3 8P (EA888.1)
Golf R (EA888.1)
Product Features:
T6061 billet aluminum construction
Black anodized stealth finish
Fully compatible with OE electronics
Fully serviceable piston design
No additional wiring required
Substantial reliability improvement over OE
Compact design fits into tight spots easily
CTS BOSS Turbo Kit for mk5 mk6 b7 b8 side by side with our 3D printed prototype. Many hours of R&D, 3D scanning and 3D printing ensure a perfect bolt on OEM fit for our kits feat. Garrett gtx2867r and gtx3071r
We are in the final stages of testing. Stay posted for an announcement of when they will be available
Boss MK5 by CTS Turbo, on Flickr
1 - 6 of 6 Posts
