1 - 4 of 4 Posts
I'm rebuilding drive shafts and just need to be sure what ones I need to order.
The inner is 100mm dia. where it bolts to the tranny so I assume I need a 100mm inner boot kit.
The outer is about 86-90mm depending on weather you measure the lip or not. So what boot kit size do I need for the outers???
Where the CV's hold on to the drive shaft it is 28mm, but I don't think that matters.
My guess would be 100mm kits all-around, but I want to be sure before I order.
Re: CV boots --> what size do I want? (zoinks208)
The earlier A2's were 90 mm both inner and outer. The later were 100 mm. Not sure where 1989 would fit in, but a parts store would tell you. The Gli's and Gti's were 100 mm. The inner and outer should be the same size unless a previous owner was messing with them.
1 - 4 of 4 Posts
