cv joint question...
614 Views 2 Replies 2 Participants Last post by  Surf Green
how many ft lbs of torque does the 30mm bolt need to be on a 98 vr6? thanks
See less See more
1 - 3 of 3 Posts
2
Re: cv joint question... (hoodwinkvr6)
come on!! do you know how many ricers are up here??? i need to get back on the road..
thanks
hoodwink
See less See more
Tighten to 50 ft-lbs before lowering weight onto the bearing housing.
Once on the ground, torque to 148 ft-lbs.
Back off 1 full turn.
Torque to 50 ft-lbs.
Turn another 30 degrees. (1/12 turn)
1 - 3 of 3 Posts
