Quote, originally posted by tolusina » |
It's been a looong time since I've done an automatic, seems popping the ball joint loose from the steering knuckle gives adequate clearance for removing the shaft. |
Quote, originally posted by dwl124 » |
when I did mine (last week), I did, indeed, strip one of the bolts, which compounded the PITA factor tenfold. Luckily, the boot kit s I purchased from GAP included new ones, but you should definitely heed the advice by the above posts, it will save you hours of work if you clean inside the bolt heads properly. |
Quote, originally posted by sehaare » |
...I'll now only use the new shafts from German Auto Parts, last I checked they were about $110. Steve |
Quote, originally posted by native-texan_in_tn » |
If you're referring to the Empi halfshafts, one might also want to check http://www.carmadillo.com/. I just found Empi there for a bit less. Shipping costs/time were comparable to GAP. ![]() |
Good find, appear to be about $8 cheaper (every little bit helps). ![]() But for me the customer service and lightening fast shipping that I have always gotten from GAP has made me personally a customer for life. I will bookmark the other site though because even customer loyalty has a price. ![]() |
