1 - 3 of 3 Posts
Discussion Starter #1
Hello,
I have a Canadian Golf with a CXB(B) engine, but can't find which iteration of the EA888 engine it is. According to one site (see link below) there are 3 versions, and I am trying to find out which one I have. Does anybody know for sure, without guesses or conjectures? Is there a way to find out?
Thank you!
M.
https://engineswork.com/engines/volkswagen-engine/1-8-tsi-ea888-engine.html
If this a 2015+ Golf then probably gen 3. Easiest way to tell is by looking at cylinder head side cover, where I believe you found the engine code. If one variable valve timing system (intake only) then it's either gen 1 or gen 2. Gen 3 added another variable vale timing system to the exhaust camshaft, so you'd be looking at two on the side cover.
https://www.motorreviewer.com/engine.php?engine_id=118
Hope this helps!
FWIW, my 2019 US Alltrack has CXB code. I found some web content that says gen 3, but am still looking for more about the CXB
1 - 3 of 3 Posts
