1 - 7 of 7 Posts
Re: Dampness?? (LeatherMK2)
get out your phillips screwdriver and remove your doorcards, check the clear plastic "vapour barriers" to see if they are still glued to the doors.. if not, replace with some other plastic.
thats most likely where the water will come in..
Re: Dampness?? (lyledriver)
quote:[HR][/HR]get out your phillips screwdriver and remove your doorcards, check the clear plastic "vapour barriers" to see if they are still glued to the doors.. if not, replace with some other plastic.
thats most likely where the water will come in..[HR][/HR]​
what he said http://****************.com/smile/emthup.gif
I consider my self the swami of the swamp. Lemme tell you why. My doors leaked I fixed the plastic. RTV and some visquene. Then it was my door seals. Easy fix. new gaskets from a junk yard. Then It was my windsheild. (some rust and a faulty windsheild install) Well I got that all RTV'd up till summer when I can get rid of the rust. Then it was a hole in my firewall where the dumba$$ PO wanted to run his Monstercable for his Big amp.
I would look into the Door cards first, as those are the most frequent offenders. If all else fails get a big tube of RTV and goto town.
Good luck Your gonna need it!!!!!!
1 - 7 of 7 Posts
