1 - 2 of 2 Posts
Vendor
Discussion Starter #1
We just release our new short shifter for preorder, and it is Currently on Sale for Black Friday!
This short shifter is a full replacement for the factory shifter parts on top of your transmission including the shift cable end links. This short shifter reduces both front to back, as well as side to side throws in your shifts. The factory shift lever and counterweight, is replaced by a CNC Stainless steel plate with shortened front to back throw. The side to side component in our shifter is a replacement component made of aluminum, which on some models is a plastic composite material from the factory.
In addition to shortening your shift throws, the replacement end links will give you more precision in your shifts. The factory shifter is designed with comfort in mind. The ends of your factory shifter cables have a soft rubber bushing in them, which will allow slop in your shifts. Our custom designed aluminum end links clamp on to your cable, and use spherical bearings to get rid of any shifter play. We have also designed these shifter end links with a notch in the rear for prying to remove.
All aluminum components are clear anodized to ensure longevity of this shifter.
Included with the DAP MK7/MK7.5 6 Speed Short Shifter
Selector Plate for Front to Rear Reduction w Gear Logo (Stainless Steel)
Relay Lever for Side to Side Reduction (Aluminum/Stainless Steel)
Shifter End Link Short (Upper and Lower) w Spherical Bearing
Shifter End Link Long (Upper and Lower) w Spherical Bearing
Mounting Hardware
How To install this 6 Speed Manual Short Shifter
Check our another video that has real world feedback on this product
1 - 2 of 2 Posts
