1999 Audi A4 Stroker Build in Progress S200SXE, Custom Megasquirt ECU, ABA Forged Crank and more
I originally had a build thread on Audiworld but I kinda lacked keeping up with it since its not really super active. Forgive me but I’ll try and cover the start of the build up until now in one post. My car is a 1999 B5 A4 prefacelift so its a dbc aeb car. The car was a stage 3 k04 up until I pulled the motor in October. I decided to build a Stroker because I lack proper decision making skills and don’t like having my money in my pocket apparently (Kidding).
Here’s the parts run down I have a decent amount of the parts so far:
Custom 83mm 9:1:1 Cp pistons with oil squirter notches and coated skirts
Spa Twin Scroll Manifold
Walbro 450
Custom PNP Megasquirt ecu
IE Tuscan Rods
IE Billet steel main caps
IE Adjustable cam gear with friction disk and arp bolt
Bartek tuning billet fuel rail
BBM fuel pressure regular adapter(this thing is beautiful I really recommend it based off feel and looks lol)
OBD1 ABA Crank
awm camshaft timing adjuster
IABED Billet Rear Main Seal and Coolant pipe
Vr6 Throttle body
44mm wastgate
Electric fan Conversion
Metal Slave Cylinder
JRE Crankcase breather plate
034 big bore head gasket
Coated main bearings
Coated rod bearings
Intermediate shaft bearings
Crank Dowel Pin kit
ARP crank bolt (207-2501) This is for a Toyota but I can confirm it fits and is the same length may be 1mm shorter ENDED UP SWAPPING THIS OUT WITH THE FORD DURATEC ARP CRANK BOLT)
ARP Main studs (204-5402)
ARP Cam Cap Bolts (670-1005) haven’t confirmed whether or not they fit yet.
Various OEM gaskets and hardware as well as other less interesting parts
AN fuel hoses
Various hoses and adapters
06a updated none hydraulic timing tensioner (going to take measurements since the offsets of all the pulleys on 058 blocks are different than 06a)
Ringer Racing Stage 4 Clutch and Flywheel
SEP 1400CC Injectors
S200SXE
Cat Cams 3568
B7 02x TDI fwd trans
Facelift uprights or b7 a4 uprights.
That’s all I’ll list for now since a lot of the other stuff is boring but feel free to ask! The 058 block is neglected in certain ways so it can be hard to find things like arp hardware etc that’s why I listed the part numbers.
Here’s a photo dump from the past few months:
Towing the car to storage in early November
10x20 storage unit is where my car has lived for the past few months
pulling the motor
Not much happened since I pulled the motor in mid November
Fast forward to about 2 weeks ago I drove to penn to pickup an obd1 aba motor for its crank. It was the weekend of the 29th which was when the huge winter storm hit the northeast so that was fun. My buddy came along for the adventure so it honestly wasn’t that bad.
Tearing down the aba motor
The aba crank is in pretty decent shape
Aeb head thus far
IE main caps
yesterday I test fit the main studs and caps all checked out.
There are tons more pictures but I'll try not to bore anyone. The block is going to the machine shop once my pistons come in, should be another month or so. I’m hoping to have the rest of the parts I need to be ordered by may. It’s been a really fun project so far I looked forward to what’s next. Well, anyways I’ll try to keep this thread updated as I make more progress thanks for reading!
Sent from my iPad using Tapatalk
Walbro 450
IE Tuscan Rods
OBD1 ABA Crank
Vr6 Throttle body
44mm wastgate
Coated rod bearings
Crank Dowel Pin kit
AN fuel hoses
S200SXE
Cat Cams 3568
pulling the motor
Aeb head thus far
IE main caps
