Daytime running lights
1001 Views 21 Replies 17 Participants Last post by  vwbrvr6
One very simple way to disable the DRL on Mk3's is to actually pull the relay under the dash and above the fuse panel.
1. Flip down the fuse panel and above the fuses should be a few rows of relays.
2. You will find the DRL relay in the third row up. It is marked with a big 173 on the top or the part number will either be 431 951 253 F or 3A0 941 589.
3. You can pull this relay without effecting anything else in the electronics.
1 - 20 of 22 Posts
2
Re: Daytime running lights (twiztidvw)
Take the easy waaaaay out
eurooo switch
Modified by jayseal22 at 10:44 PM 6-28-2003
See less See more
3
Re: Daytime running lights (jayseal22)
Quote, originally posted by jayseal22 »
thats the costly way out..but you do get some cool extra features http://****************.com/smile/emthup.gif
See less See more
Re: Daytime running lights (abdrury)
or just put electrical tape over the TFL pin on your head light switch
Just adding a euroswitch won't kill the DRL's...........plz. read the DIY thread at the top of the Mk3 forum and find out....
Re: Daytime running lights (golfkart)
Quote, originally posted by golfkart »
drl thread
I cant see what does that say on it again
See less See more
Re: Daytime running lights (slammed dub)
i'm gonna try this....
See less See more
Re: Daytime running lights (WOB GMAN)
this way is easier and cheaper than taping the TFL pin
Re: Daytime running lights (RacinJetta)
yeah you just flip on the running lights the car looks really goo dith the corners highlighted and all that
is that a rear fog light? on that euro swith, because the glx mkIII came with i guess half euroswitch,
i got daytime running lights and if you turn right and out the fog lights come on, so whats that extra fog light?
Re: (A4willie)
Quote, originally posted by A4willie »
Yup, that would be a rear fog light.
See less See more
Quote, originally posted by twiztidvw »
If you pull the fuse 173 out, you won't have the light in your instrumental cluster saying your parking brake is engaged.. at least mine does that.
c.
See less See more
Re: Daytime running lights (d6)
My bad I did overlook that. I guess I really don't look to see if that light comes on when I pull my parking brake. Sorry for the misleading info.
wow thanks for the new information, mad scientist
(i didnt see it in the DIY thread about 5 years ago)
See less See more
i actually like having the DRL's......on my stock lights that is of course http://****************.com/smile/emthup.gif
See less See more
Re: Daytime running lights (iwannavr6)
i just cut the yellow wire coming out of the head light switch harness, no more drl's http://****************.com/smile/emthup.gif
See less See more
Re: Daytime running lights (MrVrSix)
i still think taping the TFL pin is the easiest. you don't need to unscrew anything to get to the fuses. all ya do is pop the headlight switch out, unplug it, tape the pin, and plug it back in, it takes all of 10 sec. and if for some reason you ever want your DRL's back, just take the tape off
Re: Daytime running lights (Madtac44)
well you can always put the relay back into place also. I don't see the trouble in that.
1 - 20 of 22 Posts
