1 - 3 of 3 Posts
Hi, I'm having problems with the drive by wire pedal in my 1.8t swapped car. Anytime suddenly, the pedal just stops working and I'm just fed up. So my question is if I can put a drive by cable throttle body on it, connect the correct pins for the TPS and run with the original DBW ECU? I have searched but have found nothing about it.
Thanks!!
You might be able to do it; but you will have a permenant CEL and EPC light...
Have you scanned your ECM for DTCs with VAG-Com? Might be a dying switch or something in the pedal. A much easier and probably cheaper fix than swapping to DBC.
1 - 3 of 3 Posts
