1 - 4 of 4 Posts
my friend has a v8 which was idle for about 3 weeks. when he tried to start it, nothing, nada, zero. on both the starter and aux battery. AAA tried without any success to jump start it, and after the car was taken to a private shop the battery was charged, again nothing. as no power, no way to get codes he is told. any ideas observations?
Vag code reader . Clear all codes . Then try to start again with both batteries fully charged. Need solid 12 volts turn key right left several times. Then. If nothing. And all kessy codes are cleared. Disconnect both batteries. Touch aux battery pos. To ground. For 30 seconds . Then connect both batteries. Try again to start. Start sequence should engage if all is cleared. Good luck
1 - 4 of 4 Posts
