1 - 4 of 4 Posts
is it something i want to do ? pros and cons ? what exactly does it do to my engine ? im going to be decking a kr head and slapping it on my 2.0 9A block with a 50mm manifold.
also: my gti was a 1988 1.8 16v KR so whats my fuel system ? CIS ? thanks in advance
Re: DECKING (liquidtension)
decking the head will raise the compression ratio. more pressure in the cylinders at top dead center means more torque and hp. if you increase your compression ratio you will need to use higher octane fuel. my 9A's cr is 11.5:1 and if i don't put 93 octane in, it knocks and burns headgaskets.
if you raise the cr too much, you will have to retard the ignition timing, which will counteract any power gains you made by the cr change.
Re: DECKING (diablerouge)
Quote, originally posted by diablerouge »
how much did you have shaved off to get 11.5-1?
1 - 4 of 4 Posts
