Ok so I'm at a dilemma. I'm trying to decide if I want to go the defcon route or put the extra money into ARB bushings. What would you pick between these 2 options? They both equal to the same cost $$ wise so that's why I've got the ARB bushings in the second option but not the first. I'm thinking the 2nd option would be the stiffest as it's not rubber OEM bushings.. but on the other hand, are Defcons THAT much better than full poly?
1. Defcon 2
Defcon adapters
Front control arm Front OEM rubber bushings
Front control arm Rear OEM Bushings (solid from mk2 TT)
Bolt Kit
OR
2. Full powerflex setup with ARB bushes.
Front control arm bushing front Powerflex
Front control arm bushing Rear Powerflex
Rear Powerflex ARB
Front Powerflex ARB
1. Defcon 2
Defcon adapters
Bolt Kit
OR
Rear Powerflex ARB
Front Powerflex ARB
