1 - 8 of 8 Posts
Here's the wiring for this sensor, as stated by DEI's instructions:
Quote »
Yellow = ground
Red = +12 v constant
Blue = Trigger output for heavy impacts, connect to factory alarm
Green = Trigger output for light impacts, connect to other DEI equipment
I'm tying this in to the stock alarm on an A4-chassis GTI. Do I disregard the green wire entirely, or can/should I connect it to the blue wire?
Re: DEI-504M shock sensor: Trigger question (Enfig Motorsport)
Quote, originally posted by Enfig Motorsport »
Disregrd it or you can hook it up to your hown for a warning chirp
Really? Will that work with the stock alarm/horn?
· Banned
Re: DEI-504M shock sensor: Trigger question (Helicon Twist)
It will if you hook it up with a relay I'm not sure if the horn trigger at the comfort control module will sound with the car off? But if you wire it directly to the horn it should work
lol Now I want to do it
Since the alarm sounds the horn when triggered, then the horn trigger should be "hot" with the ignition off...
If the sensor output goes directly to the horn, that would mean the sensor was powering the horn directly, right? Is there enough output on that skinny green wire to do this? Granted, it is just a short "chirp."
Quote »
· Banned
I think the horn trip from the comfort control goes through a relay so there might be enough to trip it. Worst case senario you can use a relay
· Banned
C'mon brother how can you take his work over mine. It can be done and now I have to do it
1 - 8 of 8 Posts
