1 - 9 of 9 Posts
i want to install the VR6 center console gauge pod (voltimeter and BAR) on my G60 i know its been done before, has anyone done this before? any help would be appreciated... anyone have a diagram?? let me know, thanks guys
-Andre
Re: diagram for the VR6 center console gauge pod in a G60 (CORRADOFREEK)
i know but thats for the VR6 set up, its different on the G60 i think you even need an adapter for the oil pressure gauge or something...
-Andre
Re: diagram for the VR6 center console gauge pod in a G60 (Wonderwop)
the vr6 pod doesn't fit in the g60 its like 1/4" to big if u shave the bottom or top it will fit..
and you have to get a oil sender (digital) to the bar..
Theres 4 wires.
Grey/Blue: Dimmer +
Brown: Ground -
Black/Yellow Ignition 2 +
Blue/??? Oil Press. Sender -
Dimmer can be attached at cigarette lighter.
Ground can also be attached at cigarette lighter.
Ignition 2 can also be attached at cigarette lighter.
Oil Pressure sender is the only wire you will have to route into the engine compartment and connect to the VR6 oil pressure sender,it will have to be bolted to the oil filter housing.
1 - 9 of 9 Posts
