1 - 20 of 22 Posts
hehe no but i wanted to do this for a long time.. and i was bored at home so i tried it.. almost done... just need to do some wire and blah this blah that.. heh
here are some pics.. cuz ppl wouldnt know what i'm talkin about heh
the lense is hella lense too..
few more pics... with lights on..
the bulb is yellow fog bulb
[Modified by BlueVR, 8:49 PM 4-8-2002]
Discussion Starter · #4 ·
Re: Did Hella came out with new Headlight? (igneousGOlF)
quote:[HR][/HR]I'm confused
[HR][/HR]​
dont know what it is? hehe.. look closer..
quote:[HR][/HR]woohoo, looks cool.
are u using parts from a real mk4 lights [HR][/HR]​
if i had real MK4 light.. i would try to mod that and put it on my car..
the fog light is from hella DE fogs..
[Modified by BlueVR, 8:06 PM 4-8-2002]
[HR][/HR]​
it's a fog light dude. mkIV look lights don't have those the. mkIV lights have those available though. good work.
[Modified by farfrummugen, 8:15 PM 4-8-2002]
Discussion Starter · #11 ·
Re: Did Hella came out with new Headlight? (farfrummugen)
quote:[HR][/HR]it's a fog light dude. mkIV look lights don't have those the. mkIV lights have those available though. good work.[HR][/HR]​
yeah it's available for MK4 cars... but not for MK3 MK4 look ones..
Discussion Starter · #13 ·
Re: Did Hella came out with new Headlight? (VReihenmotor6)
quote:[HR][/HR]how does it fit depth wise is the fog to long or not to fit in the mk4 look housing?
good work man
how do you think the aiming of the fog beam will work?[HR][/HR]​
i have to make custom housin.... it will work good
just need more time.. heh
oh the aiming will be used with the headlight adj..
Re: Did Hella came out with new Headlight? (BlueVR)
do you want these to be a driving light or a fog
because if they are supposed to be a fog chances are if they are aimed along with the head light they will become a driving light
enlarging the housing wouldn't work for me on my car but looks like it will turn out well for you
good luck
Cool. Good luck http://****************.com/smile/emthup.gif I've got an extra Mk4-look light that I robbed the lens off of and a set of MicroDE's on my workbench and eyed doing the same thing a while back but chickened out because there is going to be A LOT of custom fabbing on the back. (I just hate the way the Mk4-look lights have a "fake" fog bump...better to have left it off all together.) It will be definitely cool when you're finished! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
But then, your car already IS
Discussion Starter · #16 ·
Re: Did Hella came out with new Headlight? (KeithVH)
Thanks Keith.. i had the extra MK4 look headlight too.. and a broken Micro hella DE fogs.. that's why i'm doin this.. hehe..
yeah i guess it will be more like a drivin light than a fog.. i'm runnin 20W yellow fog bulb so that it doesnt heat up too much...
Re: Did Hella came out with new Headlight? (Dr. Blingonian)
Let us know how it turns out. I have two extra mk4s sitting in my room. Might as well make something useful out of them !
Does the fog actually help out with lighting, or is it just for show ?
Discussion Starter · #20 ·
Re: Did Hella came out with new Headlight? (ToughGuy)
quote:[HR][/HR]how is it on "melting" i thought about doing it but potter told me many guys have done it but sooner or later the little chrome ish melts.[HR][/HR]​
if the chromeish melts.. than my headlight chrome part should be all melted by now (i run both high beam and low beam on same time.. also had my MK4 lights for about 3years now..).. cuz headlight bulb uses higher watt bulb.. 55W or some ppl use 60or higher..
that's why i'm usin only 20W bulb so that it doesnt heat up that much.. i'm also going to test this befor i do it to my headlight..
going to leave the light on for couple hours and see what happens.. if any of the plastic part from the headlight melt.. than i might not do it.. or not leave it on for too long..
1 - 20 of 22 Posts
