1 - 1 of 1 Posts
I changed fluid in both differentials and the transfer case today. All 8mm hex plugs came loose without issue, some corrosion in the front diff full plug that had to be cleaned but that was it.
168895 km’s
Oil was black. Trans case oil seemed the worse.
I filled with OEM fluids and replaced all drain and fill plugs.
Trany will be next.
Water Plant Automotive tire Rectangle Window
Plant Botany Hood Grass Tree
Plant Automotive tire Dishware Picture frame Twig
Automotive tire Motor vehicle Automotive design Bumper Automotive wheel system
Automotive tire Tread Automotive exhaust Fender Automotive lighting
Automotive tire Motor vehicle Automotive exterior Hood Vehicle
1 - 1 of 1 Posts
