Re: difference between 16v and 8v fenders...????? (LeatherMK2)
depends on the 16v fender, the 1.8l fender is identical to the 8v fender. the 2.0l fender is factory cutout for tire clearance and has square holes under the flare to hold down the flares with a special clip.. its the flares on the 2.0l 16V's which are wider, they are also called g60 flares, they have a clip molded into the back of them that attaches to the fender like i mentioned. to use these flares on an 8v u have to cut the clips off and use liquid nails or similar adhesive to get them to sit right on the fender.
