1 - 4 of 4 Posts
hey can anyone tell me everything i need to change my car over to diaginfant 1 for a g60. i am put a 2L 16V turbo in to my mk1 and want to run diaginfant 1. i know i need the wireing/ecu/mass /air flow/ sensoer/injetors/ what esle would in need? thanks for the help
Re: digafant 1 please help!!! (turbo_jeff)
can't tell you everything, but it has been done before. the hardest part is the wiring, which isn't too bad. No Mass Air Flow Sensor. Digi-1 uses a Manifold Absolute Pressure sensor mounted within the ECU.
There are a couple of Scirocco 16V digi-1 conversions running around now. One with nitrous and one will be turbo soon.
Re: digafant 1 please help!!! (jwatts)
i just did the swap, email me and ill give you all the info you need, i dont know much about the wiring in a mk1... i did it in a mk2 16v. but i will do the best i can and i can give you info from websites.
1 - 4 of 4 Posts
