1 - 5 of 5 Posts
Ok, posting this here as well as the mk2 forum.. Thanks
Ok.. did a search without anything concrete. I haven't played with digifant in years so I forgot all the culprits.. Anyways, the car runs great but when you let off the gas, it drops down to almost 0 RPM (sometimes it will die) then jumps up to 1200, back down to roughly 500-600 then idles normally (though the car seems to idles with some vibration in the car) So yesterday. while the car was running, I disconnected the ISV and it instantly stalled. Would that eliminate the ISV as the problem? I still plan on cleaning the ISV, checking the intake boot for tears, pulling the upper intake off and cleaning the sensors, and checking for vacuum leaks. I did a search, but did not see anything specifically related with solutions. Thanks for reading and I look forward to your suggestions.
Brian
Re: digi idle problems (blackgold)
I have a similar problem. Car idles at 900-1000 then jumps up to 2100 for a bit. Then goes back down to 900. Sometimes revving the engine will cause the idle to stay high as well.
per the bentley when you disconnect your isv while the car is running you risk the chance of frying your ecu...... if I were you I would do a search on how to completly remove your isv and never have another problem with it again this is what I did.... I'm me if you want pics of what I did
I don't mind the ISV on this car.. I am thinking of deleting it on my G60 though... And Lewis. it might help if you included the link
Thanks for the bumps I should get my injector O ring kit tonight.
Brian
1 - 5 of 5 Posts
