I changed the cyl head on a 90 jetta (digifant) The car ran fine before I start working on it. After the new head was put on the car started ok but after 2 minutes it started to run very rich so rich that it is not drivable
O2: Replaced with new generic Bosch. No change at all
Ground: 2 brown wires are attached firmly to the head I can get 12 v when connect a volt meter to positive terminal of battery and the ground wire. Terminal 1 on ECU harness is also getting good ground.
ECU: replaced with another working unit. No change
Blue temp sensor: Values checked on blue temp sensor and ECU terminals.
If I unplug the O2 wire or disconnect the blue temp sensor the car runs fine with no problem. As soon as I plug them back it starts to run very rich so rich that I can not go faster than idle.
Any ideas?
Modified by kickster at 9:03 PM 6-20-2005
Any ideas?
