Re: Disable DRLs with Euro Switch w/ TFL pin already bent (kodomokid)
huh? you sure you took the correct pin out?
Quote, originally posted by hotsoup » |
huh? you sure you took the correct pin out? |
Quote, originally posted by kodomokid » |
I need some help. I just bought a euro switch for my 99 Passat and disabled the DRLs by bending back the "TFL" pin in it. It works fine, no DRLs while driving with the switch in "off" position. But when I go to turn on my parking lights while I am driving, those damn DRLs come on.
Quote, originally posted by BillTchr » |
I don't know if the B5 Passats had them, but are you perhaps talking about the city lights? (The little, 5W, bulbs usually in the high beam reflector...) If that is the case, then when you turn the Euroswitch to parking lights (middle position), you should get: instrument lights, side markers (not the turn signal repeaters), rear lights, and then the city lights (instead of the amber turn signals). When you turn it to full on, it's all of the above plus low beams. If it IS the city lights, that is exactly what is supposed to happen. If you get your amber turn signals plus low beams at a lower power in the middle position, then I haven't a clue what might be happening! Bill |
