Thanks to everyone that helped solve the problem and to those pictures that I borrowed in addition to my own. Certain MKV's (yes, 2007 models too like mine) develop a rattle in the air diffuser above the two central vents and stereo. In fact, some people with the replacement tray even experienced this rattle. Here is the fix:
Tools needed: Torx 20 screwdriver, wedge of choice (explained), and a trim removal tool (or flathead screwdriver http://****************.com/smile/emthup.gif )
Time to complete: 5-20 minutes
(P.S. don't be afraid to do this one yourself, it seems relatively fool-proof and easy to follow)
1. Pry out Air Diffuser control panel (plastic trim removal tool was used in this picture, but I managed with a small flathead screwdriver
2a. Pry out Air Diffuser grill using the same method
2b. It may be necessary to unplug this connector for some cars (not mine)
3. Unscrew this Torx-20 screw
4. Pop out the black plastic cover by pulling up as shown in the picture
5. Unscrew next two Torx-20 screws
6a. Pull UP on the air conditioning vent unit to remove it. This requried the most strength... don't be bashful.
6b. Do NOT unplug this cord: it will cause an airbag fault and disable your airbags. The cord gives you enough slack to set aside the vents with room to work comfortably.
Now, everything that needs to be removed has been done http://****************.com/smile/emthup.gif .
Find this area in the remaining part of the dash:
Wedge something (1/2" height has been the estimated size... but don't hold that against me) into the space (to absorb shaking?) as seen in the following pictures. People have used things ranging from blocks of rubber, blocks of wood, or I used a malleable piece of metal.
Two temporary (albeit desperate
) fixes:
Wooden blocks
My solution (one of my sister's metal bracelets that bends
http://****************.com/smile/emthup.gif Thanks again to everyone that helped! If your car is a 2006 model and this still didn't work, you may consult this dealership method to fixing a different (but nearby) rattle: http://www.alldata.com/tsb/Vol....html
Similar post: http://forums.vwvortex.com/zer...age=1
Wooden blocks
