97 parts list:
Wiper stalk from 97 car with the changable stalk.
Lcd cluster
Dash wiring harness from a 97 car. The harness unplugs in both kick panels and at the power distribution block behind the drivers knee bolster.
if you have a 1.8t and the cluster is from a 2.8, you will need to recode the cluster via vagcom. (Open vagcom, click instruments, click recode, read ur original clusters code, write it down, when you put new cluster in, recode it with your old code so the tach, mpg works, etc.)
98-99
you can use 98, 98.5, or 99 dash harness.
Will also need the stalk.
Cluster between 98-99.5 (cluster can be 99.5, harness cant be) they have analog clocks.
Same install directions as 97.
99.5
99.5 only dash harness.
98-99.5 cluster
Same install as 97.
I am currently working on a 00-01 lcd into an older car (digital clock). 00-01 are ME7 electronics and the interior wiring and ecu wiring pinouts are completely different.
My car is a 99.5, so i used a 99.5 lcd harness to keep my ME5 ecu happy. i got a gray 32 pin connector and grabbed my bentley. I spent 4 days rewiring my dash plugs. You dont use all the pins cause the ME5 cars dont use canbus like ME7 cars do.
I will be posting my wiring diagram once its finished.
I got everything to work except i get a false brake light out.
NOTE: YOU WILL GET A LOW WASHER FLUID LIGHT IF YOU DONT BUY THE SENSOR, REMOVE THE PLUG IN YOUR BOTTLE AND WIRE THE 2 WIRES UP.
Lcd cluster
98-99
99.5
98-99.5 cluster
Same install as 97.
