posted this in my other thread but im making a diy so that people can search for it by title
heres the run down:
when the Clutch switch fails its the spring inside that fails which causes the plunger to be stuck inside the housing and not rebound..
a quick fix is to do what i did: take the sensor apart, and take the bigger part of the broken spring and stretch it, put it back into the switch and discard the smaller spring piece, your switch now works again and you saved 42.xx bucks
Due to confusion some people, myself included, have about these 2 switches heres descriptions and part numbers
CLUTCH switch 1J0 927 189 C
**if your car starts without pressing in the clutch, this sensor is bad(see above for quick fix)
removal is easy, located on clutch bracket, unplug and twist and the snsor pops out, when installing new sensor, pull plunger all the way out till it stops clicking, insert into bracket and twist
CLUTCH POSITION SENSOR P/N 1J0 927 189
**if your cruise control doesnt work or your rpms hang during shifts, this sensor is bad
for removal and install reffer here: http://forums.vwvortex.com/showthread.php?1158315
heres the run down:
