City Light Bulb Install
Parts Required: 2 W5W Bulbs
Tools Required (optional): Small Flat Head
Step 1:
Pop the hood
Step 2:
Locate your city lights
Circle: Where city lights are located externally
Arrow: Where city lights are located internally
Note: May have to refer to side step, see below
Step 3:
Locate your city lights internally.
They are located inside the smaller of the two rubber covers behind your head lamps.
Circle: Smaller of the two rubber covers.
Step 4:
Remove the smaller of the two rubber covers.
Step 5:
Locate the city light bulb housing. It will be inside, and to the right, of the smaller rubber cover.
Circle: City Light Bulb Housing
Note: This picture was taken side ways you may want to refer to the actual sight picture found below.
Step 6:
Pull/Pry out the city light bulb housing. Located on either side of the city light bulb house are flat spots. I found it easier to use a small flat head and pry it out myself. If you can get it out with your fingers by all means do so.
*DO NOT PULL ON WIRES*
Arrow: Flat spot, on city light bulb housing, I used to pry out the city light bulb housing.
Step 7:
Replace your city light bulb with the W5W bulb you chose. This is done simply by pulling out the original bulb and replacing it with the aftermarket bulb.
Step 8:
Put the city light bulb housing back into the hole. You will hear a slight click when the housing is in completely.
Circle: Hole where the city light bulb housing goes back in to.
Repeat for opposite side of the car.
Step 9:
Remove anything you may have used from underneath the hood and close your hood.
Step 10:
Find a dark area to check your new city light bulbs out. If you do not have a Euro switch simply flip your lights on with the ignition off.
Side Step:
I have an intake installed on my car, so to install the drivers side city light bulb I had to remove my intake to gain access to the city light bulb housing.
Before:
In between:
City Light Bulb Install Complete
Actual Sight Pictures:
Step 5:
Step 6:
Step 8:
Note: All pictures were taken of the passengers side
Modified by SnowboarderX216 at 2:38 PM 3-17-2007
Step 1:
Pop the hood
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Side Step:
Before:
In between:
Step 5:
Step 6:
Step 8:
