*Do this at your own risk*
You need an "H" type cluster or else it won't work.
Worst case scenario....you try it with Vag Com and it doesn't work....then you know you don't have the correct cluster for it to work on.
In Vag Com:
Address 17 – Instruments
Adaptation 10
Select “Staging” from the drop down list
Select “Active” from the drop down list
Save the changes
Done!
Video:
http://www.youtube.com/watch?v=VcNMr5X4Vqc
Now you might not see the cluster staging happen immediately after enabling it thru Vag Com….that’s what happened on my car. You need to key the car off & then open the door and then close it, and then key on the ignition again and then you should see it happen!
OR
Instruments ----> Adaptation
Select "indicator_celebration" from the drop down list
Select "Active" from the lower drop down list
Video:
http://www.youtube.com/watch?v=iAJhLf_KFOI
In Vag Com:
Adaptation 10
Save the changes
Done!
Video:
OR
Video:
