EDIT 2/2/18:
I have received several messages regarding the missing images in this thread. Photobucket decided to stop letting users host images on 3rd party sites unless they pay for a subscription. Thankfully there is a simple workaround this problem. If you use Chrome or Firefox, follow the relevant link below. This download will allow you to view all the previously black-holed images from Photobucket.
https://chrome.google.com/webstore/detail/kegnjbncdcliihbemealioapbifiaedg
https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/?src=api
I completed this project about five months ago and posted a couple videos showing the results. A few people were interested in a DIY, which I had been working on sparingly and was finally able to finish. I wish I could’ve made it sooner, but at last here it is.
Background:
While the R32 is the most upscale of the MkIVs, it wasn’t equipped with memory seats/mirrors like the GLX VR6 Jettas. I guess this was because the “sport” models (R32, GTI, and GLI) aren’t really suited for a luxury feature like this. I think the complications of combining the easy rear access mechanism and the electric seat adjustment was another reason 2-door MkIVs never got the memory seats/mirrors. This bugged me because all the R32 interior features (Climatronic, rain sensing wipers, auto-dimming mirror etc.) can also be found in a VR6 Jetta, but the memory seats/mirrors were a Jetta only feature for the MkIV platform (in the US market). The idea of having memory seats/mirrors in the R32 first crossed my mind a couple years ago when I first learned that GLX VR6 Jettas had this feature, but it was really nothing more than a pipe dream at the time and I never gave that idea much thought.
Last summer I caught the OEM plus bug and completed several OEM plus mods on my Jetta TDI, including the memory seats/mirrors, and I couldn’t see why it wouldn’t be possible to do that on the R32 as well. I knew that aside from having to modify the Konig seats, the rest of the swap was going to be exactly as what I had done before. I ended up spending a lot of time at my local junkyard throughout the summer, and I took some time to examine manual and electric VW seat frames side by side to see how I could possibly make my Konig seats fully electric. I quickly realized it wouldn’t be easy to convert the seats, and then found a few threads on Vortex and TDI Club in which people discussed the possibility of making 2-door seats fully electric, but it seemed all of them mentioned losing the easy rear access and the discussion pretty much ended there. After a lot of thinking, I had a plan to make the electric adjustments work, while retaining the easy rear access mechanism. It ended up taking a lot of time and work, but I was very determined and eventually got it done. I want to share this experience with the forum, especially as it’s been a great resource for me and I’ve mostly been a lurker. I felt like I can finally contribute something special to the R32 community, so I put together this DIY for those who may be interested in this type of project.
Having a donor B5.5 Passat GLX to complete this swap is essential. I wouldn’t try purchasing all the parts new and building the harness. That would be far more expensive and time consuming.
You can also use a MkIV Jetta GLX for the memory swap, but you won’t have the power folding function for the mirrors.
Parts Needed:
Do this at your own risk; I am not responsible for any damage you may cause to your car or yourself. Use common sense, and always take preventative safety measures when working with power tools, and especially welding equipment.
Content:
I really suggest you use a Passat for this swap. Using a Jetta would likely require more work despite not having to add the power folding function. I had used a Passat for the swap on my TDI, and I was actually pulling the harness from a Jetta for the swap on the R32, but when I saw how the harness was routed, I changed my mind and went with a Passat again. In the Jetta, the mirror wiring runs up the middle of the car and splits somewhere under the dash to each side. The power wires run along the passenger side door sill, then across the dash to the relay panel area in the driver side. Having to remove and install that harness would’ve been much more difficult. GLX Passats also seem to be more common than GLX Jettas at junkyards.
Here are a couple tips when pulling the parts from a Passat, the rest of the interior removal is pretty much the same as on a MkIV:
Since most of this information is already out there, I intended this section to be a list of links to other DIYs that show the interior removal process, but I found that a lot of them are really old and have dead picture links, so I filled in with my own pictures for some steps.
Mirror Modification:
Seat Modification:
Background:
Parts Needed:
- Power folding/memory mirror assemblies
- Power folding mirror switch
- Window motor modules (for power folding mirror function)
- Power front seats (preferably in black so the power seat panel matches our Konig seats). Make sure the memory module under the driver seat has the part number that ends in E. There’s an A version for the early MkIVs and B5s with CCM part number beginning with 1J0, but it won’t work with the 1C0 CCM in the R32. I’ve seen a D version on some Passats with a 1C0 CCM, which may work, but I don’t know for sure.
- Wiring harness from the seat connectors, to the window motor modules, mirrors, and power supply.
Here’s a picture of the harness from a B5.5 Passat as if it were in the car (note that everything required from the donor car for this swap is pictured, minus the seats)
The fuse 1 (black/blue) and reverse signal (blue/red) wires in the pink connector will be spliced at the driver side of the car, so cut those wires from the connector and reroute them to the driver side of the harness. You don’t have to unwrap the harness, just fish them through the tape every few inches. Do this before installing the harness.
The K-line (green/grey) wire in the pink connector won’t be used because it’s actually missing in the seat harness. I believe the memory seat diagnostics on the early MkIVs and B5s were done through the K-line, but the newer MkIVs (02+) and B5.5s (01.5+) use the CAN bus (these years apply to the US models, other markets may vary). You can remove the wire from the harness, or just don’t connect it.
- Basic hand tools including an 8mm triple square
- Electrical terminal release tool or similar
- Soldering equipment
- Wiring loom
- Electrical tape
- Angle grinder with a few cutting discs
- Penetrating oil
- Drill with a basic assortment of bits
- A few small nuts, bolts, and washers, size is not critical
- Dremel rotary tool or similar with several cutting, grinding bits
- Dremel Multimax or similar oscillating tool with several blades
- Welding equipment good for 16 gauge steel
- JB weld
- Black spray paint
Content:
- Donor car tips
- Interior parts removal
- Harness installation
- Mirror modification
- Seat modification
- Results
- Conclusion
- On the Passat, the window motors are screwed in from the back side of the regulator panel. So assuming you would most likely be pulling these parts from a junkyard car, you won’t be able to lower the window to remove the regulator panel and easily get to these screws. I would suggest popping off the lower speaker in the door (held in by rivets). The three T25 torx screws for the motor are reachable through that hole.
- Removing the center console on a Passat is also different from a MkIV. Here is a helpful guide: http://pics.tdiclub.com/data/3419/Removing_the_Passat_center_console.pdf
- Front and rear center console:
+ steps 12-33 in this guide: http://forums.vwvortex.com/showthre...-DIY-Removing-interior-parts-(e-brake-center-console-armrest-glovebox-ashtrays)
- Front seats:
- Rear seats:
- Rear speaker panels & inner door sills:
- Door panels:
http://forums.vwvortex.com/showthread.php?961163
Seat Modification:
