1 - 20 of 110 Posts
There isn't one in the facts and i thought I'd spend my three spare hours this week doing something constructive. It also clears some space out of my room
Things you'll need:
router with 1/4" straight and flush bits and circle-jig
power-drill with screw head and 1/8th and 3/8th inch drill bits
dremel with cutout bits
non-hardening modeling clay
coarse thread 1 5/8" drywall screws
2" long 6-32 threaded screws with nuts - these are at home depot and have a flat head
small washers
*maybe* wood glue
The woofers in question, oem vs aftermarket:
Step One
Remove your door pannel. I'm not going to go into detail as I'm sure it's in the mk4 faqs. three screws on the bottom, two behind the door pulls, pull and lift up. Unhook the stuff inside.
Step Two
Unhook the plug going to the speaker. Take your power drill and drill out the four rivets holding the OEM speaker to the door. It will pull right out.
Step Three
Now were going to build the baffles. Here's the easiest way to do it.
Take your router and set your jig to 7 1/4" and cut a hole. The circle left over will be 6 3/4" in diameter and the perfect size for the stock door.
Next, cut the center out of the circle you just made. You'll want to use the setting on your jig for the cutout diameter provided by your speaker manufacturer.
Next, place your woofer in the rings and use a pencil to mark the cutout holes. Put your woofer aside and take your drill and drill out the holes you just marked.
Depending on how thick your speakers are, you may need to make two rings per woofer. If you're using 3/4" mdf for your rings, you can stack two rings on top of each other and still have room for the woofer. You can fit a speaker up to 3 1/2" deep behind the OEM door skin doing this.
In order to make a double-thick ring read this. If a single ring will suffice, skip this paragraph. Repeat the drilling for the second ring. Apply some wood glue on one of the rings and use the drywall screws to clamp the rings together. Screw them together very tightly! Take a paper towl and wipe up any extra glue seeping out the outside. Depending on your glue and the temperature, the rings could be dry in as little as fifteen minutes.
Now, take woofer and rotate it so that the second set of holes are evenly spaced between the first set. Drill these holes out. You will not have eight holes drilled in your rings.
Next, take the 3/8th inch drill bit and very carefully spin the bit at high speed but very lightly touch the wood. This will in effect drill very slightly into the wood, but the bit won't bite and tear the ring apart. You will do this for four of the eight holes. You'll want to go down into the wood about 1/4".
Finally, drop a washer in the hole. You'll probably have to press down with a screw driver to get it in. Next, put the 6/32 screw and put it through the hole so the head goes in the notches. You'll want to put a flathead bit in the power drill 'cause it's a lot of screwing to do by hand. Take the bolt all the way down.
(I did these a little out of order becuase I wanted to test-fit everything before doing the full mock-up and write-up. Sorry for the bad pics)
You'll end up with this:
Test fit your rings. You may need to use a flathead screwdriver to pry the bolts into the stock holes. This is perfectly okay. Feel free to hit the ring
Step Four
Take the non-hardeining modeling clay and make a small ring around the woofer hole. This is twofold. First, the clay will absorb vibrations from the woofer. Second, it will make an airtight seal between the rings and the door pannel.
Step Five
Put your ring on the door. Put a washer on the bolt on the inside of the door. Push hard on the ring and hand-tighten the nuts on the bolts. Then use a socket inside of the door to fully tighten the nuts. Clay will come out the sides of the rings. This is good. You can smear the clay around a little to smoothen the seals on the inside and outside of the ring. If you're sound deadeing the door, apply the deadener over the clay and over the ring.
Step Six
You can now run the wire through the molding. VW was nice enough to use a VERY large mold. Some vehicles I've worked on barely had room for the stock wires, let alone anything aftermarket.
Push the wires through the door into the inside of the car. It's much easier this way. Even though the molding and the hole inside the car doesn't perfectly line up, if you put your fingers up this little hole and keep feeding speaker wire through, it will come right out inside the car.
inside the door:
the molding:
inside the car:
You can also take this time to solder the wires to the woofer:
Step Seven
Put another layer of clay around the top of the ring. This will seal between the ring and the woofer.
Step Eight
You will want to cut the drywall screws down. If you're using a double-ring, you don't have to cut them at all. If using a single-ring, you will want to cut them more than halfway off using a dremmel.
Screw the woofer in the remaining four holes tightly. Peel away any extra clay that squeezes out.
Step Nine
Reattach the stock door pannels, run your wires, and enjoy.
I hope this has helped a few people wanting to do some mild upgrades to their stock stereo system. If anyone finds any typos, it's 2:30 am, I won't be offended if you point them out.
Enjoy
Modified by pwnt by pat at 1:31 AM 3-11-2007
Re: DIY: Installing speakers in a mk4 golf/jetta (pwnt by pat)
Should go in the DIY. i did one side friday morning and the instructions are dead on. they also sell the speaker brackets for anyone that doesnt want to build the wood parts. http://www.cardomain.com/item/SCOSAVW6 problem areas for me were, taking off the panel that covers the hole (glovebox was being annoying) and drilling the rivets out. (dad didnt charge the drill so i kinda drained it by the 2 rivet
) good job pat
Re: DIY: Installing speakers in a mk4 golf/jetta (Project A2 JTA)
Thank you sir.
I will forever be a fan of mdf rings because you can make 'em exactly how you need 'em. The wood is also cheaper if you have the tools (or know someone who will let you borrow them).
I wish I knew an active mod who could put some stuff in the faq. sent IMs to a couple people but nobody responded.
I bought those Scosche adapter rings posted above, but they were too shallow for my speakers, so now I have 4 of them lying around with no use.
I wish this DIY was here 24 hours ago when I cut 3/4" MDF rings out with the circle cutter attachment on my Dremel (can't afford a router). I lost count of the number of bits I burned through... I used wood glue to hold the rings together and clamped them until the glue set, I didn't use any screws.
I also didn't use any clay, but the MDF seemed to hug the door pretty tightly, so maybe I will be ok.
Pat, are you using anything between the speaker and the door panel to ensure the sound gets out the door like the stock speaker had? I couldn't come up with a creative way to reuse the stock piece. I bought a 3/4" solid foam tube to hot glue to the edge of my speaker to fill the gap, but I haven't used it yet and I'm looking for other ideas that have less of a chance of damaging the speaker.
Nice DIY, http://****************.com/smile/emthup.gif
Modified by JettaGetUpandGo at 1:21 AM 3-11-2007
Re: DIY: Installing speakers in a mk4 golf/jetta (JettaGetUpandGo)
No sir. With the double-ring, the woofers are very close to the stock grill. There really isn't any need - at least in my case.
You can get mdf rings online. Elemental designs sells them as well as some other places.
Clamping works, but if you're drilling the holes, might as well use screws so you can use your clamps elsewhere, like on a new carpc case
The seal between the wood and the door pannel isn't bad. In the case of my doors, however, the previous owner tried to replace the monsoon speakers only to really f-up the metal. With a hammer I was able to straighten them out but the clay was necessary for a proper seal.
I'm using the double-rings, so my speaker should sit right where yours is. I couldn't tell how much room you had left there in the pictures and I don't have my door panels back on yet (silly tweeters) to look for myself.
I will definitely keep Elemental Designs for precut rings in mind for the future!
Discussion Starter · #7 ·
there's about 1/2" between the grill and woofer. I couldn't get a good pic
Discussion Starter · #8 ·
le bump.
I didn't like the adires so I tried others:
Good DIY write-up Pat.
Makes me want to go put my Kappas in finally.
Discussion Starter · #12 ·
Re: (afinley)
Exactly. There is maybe 3/4" of space between the metal and window hanger when it passes by. By using 1 1/2" of space (two rings) you can easily make a lot of room. By using clay, you can get a little bit more space, about 3/8". The woofers I mounted for this guide are 3 3/8" thick and fit both behind the door skin and cleared the window with absolutely no problems.
Re: (Project A2 JTA)
Too much slack? I would think too little slack would cause that to happen. If you rotate the speakers so that you mount them with the terminals at the bottom of the opening, then any extra wire should just lay neatly in the bottom of the door panel below where the window reaches.
EDIT: I suppose I could see how too much slack could cause that to happen too depending on where the terminals on the speaker are.
Awesome, i just wanted to make sure thats all, im going to tackle this in the spring. and some with some sound deadening.
good write up, keep up the good work man.
-james
Re: (pwnt by pat)
Nice post. May I suggest showing us how to change out the tweeters? I'm thinking about installing components in my doors. I feel confident I could handle the 6.5 part now with this DYI, but not too sure about the tweeters.
Discussion Starter · #17 ·
Re: (PaDieselGuy)
To be honest, I don't have any compact tweeters. While playing with the blown ones in my doors, I came to a few conclusions about how to get the stock ones out, though.
Where in pittsburgh are you? I'm 20 minutes up i79 from the downtown area. Perhaps we could add a part II
Re: (pwnt by pat)
I'm in the South Hills but I work up your way, so getting together at some point shouldn't be a problem.
Just finished installing everything last night. Gotta sort out what I did, adjust the levels between sub and rest of system and find out why XM unit sounds terrible. Once I do that, I'll see if I'm keeping stock speakers or not. They don't sound as bad as I thought they might so I may keep them. I'd love to pick your brain about car stereos as I've seen a lot of your posts and you seem to really know your stuff. I'll be in touch.
1 - 20 of 110 Posts
