**Sorry Mods, your report doesn't work, all I'm getting is a 404 error so it's going here. Move it whenever you feel like it.**
:laugh::laugh:*** Warning -- LOTS OF PICTURES *** :laugh::laugh:
So, I bought myself some interior LEDs from deAutoKey.com. Arrived quick, then sat there for over a month. Life was in the way. Got an extra day off so I decided “why not” I’ll have a me day. Or, at least a ‘me hour’. It took about that long mainly because I took a lot of pictures as well as wanted to not break anything.
I wanted to do a DIY because all the ones on here seem to.. well.. suck.
Overall it was a great morning project. I plan on getting some night shots tonight or tomorrow of the new interior. Next little thing on my list is license plate LEDs. I’ll do that when I feel like shelling out way too much money for them.
This install was done on my 2013 Jetta Sportwagen with Panoramic Sunroof
Notes:
• Some Bulbs MUST be sitting in the housing in a certain position. Reattach the wiring harness BEFORE you close everything back up to test the bulb and make sure it works!
• This was how I did it, I decided to use a screwdriver for some of the work, you use the plastic tools if you want
• Some of the housings (footwell mainly) had little metal housings around the plastic housing. I found it very easy to slightly bend the metal to allow it to slide right off the plastic housing. This IS pictured below.
• Some housings had little wiring harnesses that come off with each. Similar to a lanyard clip. It’s pictured below.
Here is what I used/had:
1x Flathead Screwdriver
1x Needlenose Pliers
1x Hex bit (T20 size, to be exact) -- Needed for Map/Dome and Driver Footwell
1x Old Gift Card/Rewards Card
1x deAutoKey.com LED Interior Set
http://deautokey.com/product/10pc-complete-interior-led-kit-fits-jetta-sportswagen-2011
(1) Trunk
(2) Reading/Map Lights or (3) Center dome for no sunroof option
(1) Glove Box
(2) Footwells – I did blue for mine
(2) Sun Visor
(2) Front Dome
Footwells:
Driver Side -- Remove the hex bolt to make the assembly easy to mess around with. Remove the wiring harness then remove housings accordingly. Change the bulb. TEST BEFORE YOU REASSEMBLE! I figured out the 6 little LEDs that to me looked like just circuitry, were the LEDs. So double check!
I found the passenger side easy to put my hand between the hard plastic and soft felt and push down from the top to get the housing out. Came out very easily.
Here the LEDs are the CORRECT way
Here the LEDs are the WRONG way
I found using my hand to just push down made this one VERY easy. It was just soft felt, easily moved!
Glovebox: Only the one picture, but it’s exactly like the footwells. Very easy to do. Little metal housing needs to be removed first.
Map/Front Dome:
I had the Pano option so I only have the 2 bulbs. I had to remove the little mesh grill in order to get to the hex screws holding everything in place. Same T20 bit from the driver footwell. The bulbs are “twist-in” similar to headlights. They lock in place. I used the needlenose pliers to twist them loose as the area to do it is kind of cramped. Was very easy. When you test these, twist the housing ALL THE WAY “locked” then plug the wiring harness back in. If it doesn’t illuminate, you have to reverse the bulb.
Be sure to test them before you close it up!!
Rear Dome/Courtesy Light:
There is a longer plastic ‘leg’ that controls the interior of the housing (pictured below) and once I found where that was, it was easy to pry off the PLASTIC rocker housing. This is when I used the used gift card to pry. I pulled TOWARDS the inside of the housing (from the outside of the little leg) to get the teeth around the metal harness to free it. You’ll see pictures below of what I’m referring to. Came off no problem.
Giving it a little test with the Needlenose pliers!
Visor: Also almost no effort involved. Just undo the harness, change, and replace.
Trunk: Literally had to apply almost zero force at all. Easiest one to do, period.
Notes:
(1) Trunk
(1) Glove Box
(2) Sun Visor
(2) Front Dome
Footwells:
Map/Front Dome:
Sensitive content, not recommended for those under 18
Show Content
