I've been running the plate light LEDs for a while now. I meant to do the writeup sooner, but it slipped my mind.
Parts needed:
1 6 ohm Load Equalizer
http://superlumination.com/equalizers.htm
2 39mm fuse type (AKA festoon) LED bulbs for the plate lights
http://superlumination.com/festoon.htm
some wire ties
2 sheet metal screws
Tools
a drill
phillips screwdriver
pliers
wire cutters/crimpers
soldering iron/solder (optional)
Start by removing the plate light bulb holders, 2 phillips screws in each and they come right out. Then open the trunk, and remove the plastic cover on the trunk latch, it just pops off.
there are 4 phillips screws on the underside of the trunk lid holding the liner on, remove those and pull the front part of the liner down, you do not need to take it all the way off. There are 4 metal clips also securing the liner, when you pull it down, they may get stuck. You may have to use some pliers to get them out of the trunk lid
There is a harness connector with 2 wires (orange and grey) going to it attached to the underside of the trunk lid, right in the middle. I couldn't get a good pic, but you'll find it. Unplug this and peel some of the cloth tape back to expose the wires, the load resistor will need to be spliced into these 2 wires. How you go about doing this is up to you. The LE will come with 2 splice taps, you can use these but I think the wires in the harness are too small for them to work correctly. I like to solder everything so I cut the wires, soldered them and used some heat shrink tubing on them
You now need to mount the Load equalizer somewhere where the heat from it won't bother anything (it gets HOT). I mounted mine to the peice of sheet metal on the trunk lid that hangs down, to the right side of the lid. You need to drill 2 small holes and use sheet metal screws. You can also stick something between the LE and the sheetmetal to dissapate the heat, but it's not absolutely necessary. I used an old piece of PCB board, then put some high temp silicone on back of the PCB to help stop heat from reaching the metal.
You also want to zip tie any wires that are close to where you mounted the LE out of the way to make sure they never touch it. If you mount it where I did you don't have to worry about heat on the liner as there is plenty of space between them. I also had to extend the wires to the LE as the ones on mine were not quite long enough to reach
Now pop the liner back on and screw it back in. Put the LED plate lights into the bulb holders. Unlike the stock bulbs, LED plate lights have to be put in a certain way, mine were not marked so there is no way (other than using diode check with a multimeter) to know wherther they are in correctly until you turn the lights on. If one or both does not work, take them out and turn them around.
This is a bad pic, they do light up the entire plate and don't look "spotty"
It's not too complicated just a little time consuming. You can just go out and buy some of those LED look bulbs, but nothing looks quite the same as LEDs.
Parts needed:
some wire ties
Tools
a drill
pliers
