I tried this out today; it worked great so thought I'd share.
This will lift the car 9.25" (23.5 cm), more if you add additional planks or scrap wood.
It cost me about $35, but that's because I already had some planks for the front ramp and some cement blocks for the same section. If buying everything outright it would be more like $50.
Here it is
It might look sketchy, but it's easy to position everything and the car is very stable once in place. Just measure the wheel path between the planks to get everything parallel. It seemed to be the perfect distance/height to work below with a creeper. I put a beefy new Whiteline rear swaybar in this morning.
Nothing is bolted or screwed together, which makes it easy to stow away afterwards. I used 2X8 lumber throughout. Two 10-footers for the flat part, another 2X8X10 cut in half make up the ramps. Its an easy grade to climb. You'll want to place a block of scrap or a piece of firewood under each ramp at mid-span (not all the pics show this).
The ramps can be removed once the car is in place.
Here it is
