1 - 20 of 43 Posts
Well i thought it is time to give back to the community soo.
I have searched and only found ways of modding the car to accept the seats but i thought to myself how about if i ever want to go back to mk3 seats again? well i didn't want the added work so here is my DIY.
Thank you to my buddy glxguy for the idea.
Tools you will need
Sawsall with small metal blade
welder
T25 torx screwdriver
picks
hammer
visegrips
common sence
1)get a mk3 and mk4 seat side by side
MK3
mk4
2)trim this wheel on the door side only until it's about 8mm thick like so
3)have to remove the plastic trims
4)you have to cut the old braket from the mk4 seats with the sawall and bend the tabs away to cut the rest like so
5)this is the outcome
6)remove the braket off the old seat
now you see it
now you don't
7)grind the paint of the supports and tack your mk3 seat bracket in place
Make sure you only tack it in place to test fit the seat. you may have to play with bracket to get the seat to slide properly.
8)once the seats are sitting and sliding properly weld everything up install your plastics back and toss them in and enjoy.I painted everything black before i ddi the final install.
Now because the handle that moves the pin for the slider is gone i attached it to the seat with a couple of screws just like the mk3 seats.
I am sorry my camera diedtowards the end.
and a pic of the car they went into.
Disclamer
I did this to my car i will not be held responsible if you try it to yours and screw something up. I am not your mother so don't come crying to me.
Re: DIY:mk4 seats in a mk3 with a twist (Baby_golf)
so the width of the 2 rear sliders are the same on mk4 and mk3 seats... all yur really modding is the middle slidding rail?
thats very helpfuly, I think ill do that when I can find a nice set of leather... thanks
Re: DIY:mk4 seats in a mk3 with a twist (i4turbo)
Looks really good. http://****************.com/smile/emthup.gif
Very nice DIY
Also, good looking car http://****************.com/smile/emthup.gif
Quote, originally posted by Baby_golf »
nice DIY.. those seats look kind of beat tho
Discussion Starter · #8 ·
Re: (optiks)
Quote, originally posted by optiks »
i love this idea but im missing how you adjust them now with the handle gone
the handle is not gone it is there i just welded a small bracket to the side and screwed the handle arm onto it so there is adjustment there but you just can't see it . It is hidden under the plastic trim.
Discussion Starter · #9 ·
Re: DIY:mk4 seats in a mk3 with a twist (brobs is back)
Quote, originally posted by brobs is back »
They are very very dirty and i didn't have time to clean them
Discussion Starter · #13 ·
Re: FV-QR (95VRT)
I have made brackets for the rears I will post it up soon
There is more fabrication involved
Disclamer
lol http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: FV-QR (Baby_golf)
are you hooking up the heat ? its very simple with the mk4 switches besides the nancys on here that cry about how it looks in the dash
Re: FV-QR (optiks)
I like contrast in the interior. You should add some more tan parks like the puffy part and the door cards and stuff...
Discussion Starter · #18 ·
Re: FV-QR (optiks)
I haven't had much time to play with the heating I have been sorting the car out. I bought it with a few problems (mostly wiring) so i am slowly working my way through them.
awesome dye. i already have mk4 seats on my car but i couldnt get them to slide. :S and how did u deal with back seats.. i cant get them str8 100% they keep falling on me
Discussion Starter · #20 ·
Re: FV-QR (effdbmx1)
Quote, originally posted by effdbmx1 »
I accually just installed those cards the car is a tdi with manual windows and the cards are out of a glx with power. There is a small marking on the back of the glx door card where the hole for the manual windows goes . so just drill it out .Remove the handle assembly from your cards and install them on the glx cards.and you have puffy manual window door cards.
Modified by Baby_golf at 4:31 AM 2-16-2010
1 - 20 of 43 Posts
