This is an addition to the following DIY, specifically for the 2007 GTI http://forums.vwvortex.com/zerothread?id=2577068
When I attempted to follow the said directions I found to my discontent that in the 2007 GTI they DELETED the plastic ring. So now I was left to try and figure out what was making the noise. I found two culprits...
Problem 1.
Retaining Bar. This bar would vibrate against the swing latch. For whatever reason it did not have foam padding like the right side bar. Solution... Put some scotch mounting tape on it and leave the cover attached.
Problem 2.
Plastic Bracket. This horizontal bar seems to protect the sun roof motor.
Solution... Stick a pad of some sort in between the bracket and the outer rim of the console to bolster it and muffle the vibration.
I hope this helps those who have that overhead console rattle! Its a pretty simple fix ... Just use a credit card to pop the faux speakers then pop something into the aforementioned places and you are good to go!
Modified by HoneyNutz at 10:10 PM 3-22-2007
Problem 1.
Problem 2.
