My E30 has been running like crap, and after replacing most of the usual suspects*, I'm down to a few things to try, one of which is a smoke test to find vacuum leaks in the intake (I tried starter fluid - no luck). I recently stumbled across this:
http://forum.e46fanatics.com/showthread.php?t=445181
* those would be: air flow meter, intake boot, fuel pressure regulator, coolant temp sensor, idle control valve (tested), throttle position sensor (tested), plugs, wires, cap, rotor, coil, ecu
Anyone do one of these before? Got any tips? This looks promising. I hear (later in that thread) the ACDELCO 60Gs are the way to go for the glow plug.jbeurotech said:Build this smoke machine for under $30 and be able to find vaccum leaks the correct way!! Carb clean will not show most vaccum leaks, this will help you find those very small vaccum leaks!! This inert smoke will fill the intake and leak out the smallest leaks, indicating where you have an issue. This is the only way to properly find a vaccum leak!! Our profesional machines work better. However most of you DIY's do not have the money to drop on the tools that we use. But this will get you close!!
