I have it all in a word doc w/ each picture resized to the page :beer:bump for greatness. awesome, detailed diy. got a pdf file for this? too many pictures to print or copy paste into word. lol
I do have a PDF version that I included with my kits. I have it in 1 file, and a 6 file version depending on your email provider's attachment limit.bump for greatness. awesome, detailed diy. got a pdf file for this? too many pictures to print or copy paste into word. lol
Another good info reply... thank you good sir. That's encouraging too... so what you're basically confirming is there IS indeed a 'T' connector there for the AWD engines? It seems to me there is but it sounds like you have some further experience to confirm that.awd's have slightly different hose routing, and i know what you mean about them being confused at the dealer because they were looking at an AWW/AWP diagram. I sold my n249 assembly or i'd take a picture for you, but good luck :thumbup:
i offer this service. $50. pm me.for a programmer that cancels the emissions CELs, eurodyne maestro you can delete them yourself so they never pop up again, and I know APR will do it if your Stage 3+ but thats it.
If anyone finds a tuner that will do it for them let us know!
Amazing DIY.
I was just giving you a suggestion based on what info i read. If you have two severed vacuum lines that need to be connected, a brass or plastic connector is the best bet if you can't easily replace the hose. If you could in some way try and take a more detailed picture, i could maybe get a better idea. Good luck.so what you're basically confirming is there IS indeed a 'T' connector there for the AWD engines? It seems to me there is but it sounds like you have some further experience to confirm that.
The blue balls are for the Fuel EVAP system. All of the lines are routed on the leftmost side of the engine bay. If you had a leak there, you would smell fuel. It really isnt an integral part of the Vacuum System, but it is connected to the intake to burn off fuel vapors from the fuel tank.HELLO I was wondering if you could tell me what exactly those "blue balls" are used for. I'm trying to narrow down a vacuum leak and was wondering if perhaps that might be my problem...I deleted the alot of junk under the intake the other day but not the complete setup like you have done.. thank you for your help in advance...
Installing the resistors was one of the last steps in the photo guide. A total of 4 is needed.Amazing DIY, BUMP for later reference.
Did you throw any CEL's after doing this? I bet you need a bunch of resistors to not throw any CEL's? am i right?
The only thing I have resistored is my SAI. I have kept everything else plugged in. No codes. I did however keep my EVAP system. I didn't feel it would be a good idea to delete it. I kept one of the check valves to the system and ran a vac line to it.Amazing DIY, BUMP for later reference.
Sent you a PMany chance you can make a kit without the block-off plate? and whatbout shipping to canada?
I'm having a pretty hard time getting the parts individually locally, so this kit is pretty balls for me. Good write up btw..
