Dear god, would you listen to what I'm saying for a second:
I'm not attempting to compare this to the typical APR/GIAC/Neuspeed/etc. program. I know those are about as good a torque curve as you're going to get from the stock turbo.
No, I don't want to hit the rev-limiter all the time when I want power. I would, however, appreciate a torque curve that remained flat until redline, for the sake of the sensation. If you've ever driven a car whose torque curve remains flat at redline (which means horsepower rises until redline), it's quite fun. I'm not trying to argue what's better or worse, I'm trying to argue which is more fun to drive.
Say the stock turbo was large enough to maintain, say, 15psi of boost at redline. The stock ECU calls for ~11psi of boost from 2000 RPM to ~5000 RPM, then tapers to ~6-8psi. At 5000 RPM, instead of the boost dropping or staying flat, if you could ramp it up slightly, your torque curve wouldn't fall, and your horspower would peak at redline.
You would have lost no torque, and you'd have gained some high-RPM torque, enhancing the car's power and acceleration above 5000 RPM.
