Do AWD's suck that bad?
1032 Views 13 Replies 9 Participants Last post by  whizbang18T
I have a 2000 with an AWD model engine and I wanted to know if they are really that bad? Will it make a large difference if you use a different turbo setup? Or am I doomed with this motor?
See less See more
1 - 14 of 14 Posts
Re: Do AWD's suck that bad? (lilasswang)
slap a k04 on it and you'll be one up on a AWW
See less See more
Re: Do AWD's suck that bad? (mrkrad)
Well yeah I know this, but if I had a ko4 and an AWW had a ko4 would it still be 10 hp on me?
hmm you seemed to answer your own question. It's got 10more hp on you regardless what you do. In that case, i'd suggest trading it in on a new AWP motor since they make more than the AWW motor, then you won't feel this way!
My K04 awd runs just fine.......lol.......I wouldnt worry too much about pure dyno numbers...Just put on a K04 and learn how to launch and you will beat up on most cars......
It's not so bad - there isn't any software available for AWW + K04 yet and in any case you won't be too far off once you have a chip + exhaust. Enjoy!
Re: Do AWD's suck that bad? (Srexy)
Except for a couple local AWW cars, I don't have any problems handling them with ease.
To be honest, there really isn't enough change to warrant trading your AWD in for an AWW, especially if you are planning a turbo upgrade. AWP is a bigger jump, but IMHO wouldn't be worth it either.
Tim
See less See more
Re: Do AWD's suck that bad? (Jolf)
Are you running a Stage III ATP kit on a AWD?
See less See more
What kinda mods do you have? If its stock, do the basic bolt ons and that should make you happy, if not, go with a bigger turbo lol http://****************.com/smile/emthup.gif
See less See more
I believe the fastest (and most powerful) 1.8T on Vortex is an AWD - 1.BillyT's Golf.
Re: Do AWD's suck that bad? (Overdrive)
Upsoluted, DP, Exhuast.....I guess I will never be content?
See less See more
Re: Do AWD's suck that bad? (wolfsburg_de)
the engine code makes no difference once you have changed the turbo to a larger one (K04 or larger)....
Stu
Re: Do AWD's suck that bad? (Boostin20v)
thanks for the reassurance Stu http://****************.com/smile/emthup.gif
See less See more
i like my AWD + GIAC + k04 + ATP, etc etc ...
See less See more
1 - 14 of 14 Posts
