1 - 4 of 4 Posts
Like the topic says, I was just currious about fitment with the brakes and wheels on a Jetta. I searched and couldnt find anything. I am about to get wheels, and am just doing a little forward thinking since I want to get ECS Stage III brakes eventually. Thanks in advance.
I am running a set of 17x8" momo m1's and have the same caliper and discs. I only had to space the wheel out 6mm and that was so the disc missed the ball joint. It should fit fine on the 18's. the overall diameter isn't the problem, it's the offset of the wheel and the spoke design.
Mike
Re: Do ECS Stage III fit under BBS CH 18"s or RS4 18"s?? (ScarJetta)
You could go with ECS Stage 2version2.. Larger 13.1" rotor over the 12.6" of the 993, and serious inward offset will clear nearly all 17" or larger wheels without the need for spacers.
1 - 4 of 4 Posts
