1 - 4 of 4 Posts
I recently bought a 1988 Volvo 745 T/I. I noticed that the stock sealed halogens have been replaced with glass lenses that use H4 bulbs. One is cracked, I want to replace it soon. But are these ones I have considered e-code?
Re: Do I have e-code lamps? (VWVancouver)
They will say DOT (with three nipples) or E in a circle on the lens. The light pattern will be flat with a cant to the right. Use reg. watt H4's unless you upgrade all the wiring.
Discussion Starter · #4 ·
Re: Do I have e-code lamps? (bugged)
quote:[HR][/HR]They will say DOT (with three nipples) or E in a circle on the lens. The light pattern will be flat with a cant to the right. Use reg. watt H4's unless you upgrade all the wiring.[HR][/HR]​
I have the ones with the E on them. No DOT anywhere http://****************.com/smile/emthup.gif
Too bad one is cracked, and one high beam has moisture/rust in it.
1 - 4 of 4 Posts
