Re: OMG DO I NEED HELP BAD (SHaVedGTi)
so your fab does not work, your side doors look but your hatch does not...does the mechanism for the hatch have power? does the opener on the drivers door activate the hatch release? the little noise is there? if it is then i have no clue, but if it is not, that might be on the same plug as your taillights...is it your left rear that is out? i have no idea why that would have a bearing on the situation, but your best bet is to narrow your problems down...your fuse panel does have a key inside to show you which fuse is for which device...if you interiors are not working, then look for the interior fuse (little light in the picture)....make a list of things you screwed with, devices that are related, and then march through and troubleshoot...that is why your dealer gets paid the big bucks, to try to fix f'd problems, fail miserablely, then charge you anyways
give the bently a go if you want to track down exact wire paths.
