Re: Do i need wheel spacers with my coilovers? (V arrrr SIX)
If your camber settings aren't too aggressive, you might be able to do without spacers. However, even with "normal" camber settings, wide tires can also rub against the coilovers. The only way to tell is to go take the car for a spin after you've installed the coilovers. Don't forget to get on an off ramp or fast turn. Although the tire might not rub when you're going in a straight line, the sidewall flex while cornering may cause the tires to rub the coilovers.
Good luck!
Good luck!
